Blown resistor item number r-531 on main amp. board of AVr-3600dts need to identify resistance.
  • hex666 Jul 13, 2008
    The make is Denon Mode No. AVR-3600dts
    Thank You, Jack
  • hex666 Jul 15, 2008
    Does any one have a schematic in order to identify blown resistors on main amp board number R-531 and R-320 on the Danon AVr-3600dts. Thank you
  • 2,071 Answers
Register there you can download free schematic diagram:
http://www.eserviceinfo.com
Posted on Jul 15, 2008
  • 4,234 Answers
I have requested the parts specs for you and should have them shortly, but hte more important issue is: What is the general problem. The two resistors listed are not likely to be the only problem.
Can you update this?
Thanks,
Dan
    Genius:
  • 1,011 Answers
Sir,
U want to replace the resistor for working. It will be get at following address or call the customer service for parts.
Denon Electronics (USA), LLC
19 Chapin Road, Building C
Pine Brook, NJ 07058-9777
Customer Service Call (973) 396-0810
www.usa.denon.com
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 12, 2008
  • 190 Answers
Dear customer,
You'll find all the required details on the following link
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7c9a297688f87c253cf72ba73041eb81&q=Denon+AVR-3600DTS
Thank you.. Good Luck..
    Genius:
  • 1,847 Answers
What is the make?
How to test a blower motor resistor
Unplug the electrical connector to the resistor. There are 4 terminals on the resistor block. You test the resistor block using an electrical multi-meter, set to the Ohms scale. Using the meter's test leads, check the following:
Between terminals 2 & 3, you should have 2.3 ohms resistance.
Between terminals 3 &4 you should have 1.1 ohms resistance.
Between terminals 3 & 1 you should have 0.4 ohms resistance.
A bad resistor block will generally show infinite ohms on one or more of these tests. Look very carefully [magnifying glass] for the marks which identify the terminals on the block.
May 14, 2014 | 2003 Mitsubishi Eclipse Spyder
My KICKER amp KX200.2 has a resistor blown out it is R17 i will like to know the specific resistance so i can replace it
If you look closely at the color bands on the resistor. That will tell you what resistor you need to replace. All resistors are standardized color coded. You can find out the resistance online. Hope this helps.
Aug 14, 2011 | Car Audio & Video
I got an amp from my buddy who was going to throw it out cause he broke the 0.2 to 6 volt dial. He discarded the old broken part out of fustration. Anyone know the part number for said missing piece? ...
so we know a few things...
1. you guys are inside the amp removing board soldered components.
could be a good thing since what you can do to sleuth a solution is this...
a. know that the 'knob' is actually a variable-resistor that ranges resistance from a start value to a max value.
b. you can ascertain the range by opening a similar amp and testing the resistance range as you rotate the knob.
c. pick the mid value resistance and buy a cheap resistor of that value, then just solder the resistor in place of the two knob-control bread board connectors.
voila.
May 07, 2011 | Crunch Maxxsonics P1500.1 Car Amp
Pmp3000 problem power supply.ic circuit problem.number series ic circiut..
I have a PMP5000 that I had to resurect. I had to trace out the power supply to repair it.
I can give you hint: First, a small supply runs directely from the line and generates some of the small voltages. While this starts, the main power caps are charged through limiting resistors. The main switcher is brought online and if the power amps acheive balance, then a relay connects the speakers and shorts the limiting resistors.
This is what is in the 5000 and I suspect the 3000 is similar.
In my 5000, there was arcing at one side of the power amps. The board was burned and three power fets fried. Cancer of burned board had to be carved out and traces replaced by hardwiring.
In addition, the limiting resistors were blown open, both main switching transistors were blown and 4 small driver transistors (surface mounted) and several diodes AND a switching regulator chip (surface mounted).all fried/
Hint: When restarting the unit, put a 150 watt light in series with one of side of the power input to limit the current in case you did not get all the dead bodies out.
This is a class "D" amp which drives PCM waves into a filter which is then the audio output. It is much more efficient thaan a linear amp.
Dec 24, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I Need values of resisters R-82 and R-85. They feed plus and minus voltage to power amps. amps shorted and burned resistors. The amp is a subwoofer amp in a B & W model DM605 s2 speaker. Any help would...
If the resistors were blown, the power amp which is either transistors or an amplifier package has been shorted out. The resistors are very low resistance, and used really as slow blowing fuse. The value is probably a fraction of an ohm (eg. point two ohms)
Aug 11, 2009 | Audio Players & Recorders
Nedd to identify blown resistor
how can you detect a blown resister
Jul 11, 2008 | Audio Players & Recorders
Need to identify blown resister r-531 on main amplifier board
How do you know it is specifically that resistor? I suppose you have schematics or something that is telling you R531 may be an issue. If a resistor is blown it will likely be black or discolored somehow.
Jul 11, 2008 | Denon Audio Players & Recorders
Blown Channel on an amplifier
Look for low valued resistors that may look ok, but be open. Check the emitter resistors (.22 or .47 ohms). Check the transistors in the driver circuit as well.
Dan
Jun 06, 2008 | Denon AVR 3808Ci Receiver
Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Apr 08, 2008 | Denon AVR-1601 Receiver
No speaker outputs
I know that a couple of you have had the same problem with the blowing 0.47 ohm resistors. I had responded quite a wile back, but forgot to make any updates. Kostiko is correct about the problem relating to these two 0.47 ohm resistors being blown. In my case on two different Haman Kardon models, this was true, but there could also be another issue. What i have found is even after replacing these resistors, the problem appeared to still be there. What was happening was that right after turning the receiver on, the resistors would blow again. What you need to do is replace the two small ceramic disc style capacitors on the same pcb as the fusible resistors, as they could be shorted as in my case. You could remove these capacitors completely, or replace them with a similar size of the same type, as they are really just there for filtering higher frequency noises from the power supply. You can check them with your multimeter first. They shouldn't shorted even in situe. I forget the size, but they are approximately 100 nano farads. Good luck. I have done this to my AVR135, and it has been running great for about 6 months now.
Nov 08, 2007 | Harman Kardon AVR 130 Receiver
121 people viewed this question
 Grubhead
Grubhead
