Question about Kirby Ultimate G Bagged Upright Vacuum
Shampooer not putting out suds
What is the sponge filter you are talking about that needs cleaning?
  • 357 Answers
There is a sponge right underneath the on/off knob on the shampooer tank. There is a small suds screen right beside it on the small hole that the hose fits onto. Both these things should be cleaned regularly. Here is a pic of the tank..the little black suds screen is visible to the upper right of the pic. The sponge is right behind the suds screen in the pic, so you can't see it very well. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310045439771&ih=021&category=42146&rd=1&ssPageName=mem_guide:1
Marci
Posted on Jul 31, 2008
It's been awhile since I have used my shampoo system on my Ultimate G series Kirby. Well, as instructed I took it apart and cleaned it. Now I can?t figure out where to put the ?screen cap? and ?sponge...
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 15, 2009 | Kirby G6 Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer won't distribute foam/soap evenly
Disconnect the hose from the tray - if you are getting good flow of the foam - I'd say you probably did not lower the shampooer all the way down.
If the foam is not being dispensed continuously - you may want to check:
1. Check the suds screen - make sure it is clean and installed in the tank and is clean f lint
2. Check the sponge where exhaust is inserted in the tank - rinse it. Also look for the clog under the sponge in the valve.
Good Luck
Nov 11, 2008 | Kirby G4 Bagged Upright Vacuum
Shampooer not delivering suds properly, and its not the suds screen....
instead of glue I used a rubber band to help provide an air free grip to keep it in place. Just a thin tiny rubber band around the cap then insert and it should stay snug. Mine hasn't fallen out since but if I ever needed to clean it or clear debrie I could take it out still.
Mar 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
No suds when shampooing
The sponge filter is in the large opening on the underside of the kirby shampoo tank. It is where the shampoo tank connects to the kirby. The cap the manual is referring to is the shampooer tank cap. It looks like a cup.
If the mesh screen in the hose is in place (try pulling it out of the hose and seating it in the tank where the hose connects.) and you're still having very little suds...(I'm assuming you're using Kirby shampoo as well)...I would suggest going slower when yours "laying down suds". And lower the shampooer head all the way to its lowest setting. I have found if there are a lot of oils in the carpet, the emulsifiers in the shampoo break down quickly and make the suds "disappear".
Be sure to go back over the carpet with the tank in the off position to scoop up any excess moisture. If excessive oil (from cooking, barefeet, and pets are main causes) is the cause of the lack of suds, numerous shampooings will rectify that situation.
Hope this helps!!
Feb 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Shampo system
here is a site that has detailed instructions for using your kirby shampooer.
the screen that goes in the hose is different from the filter (round flat sponge) that goes between the exhaust side of the kirby and the shampooer tank. The screen is what makes the suds...if its not seated properly or missing (or damaged) then it won't make suds.
http://www.greatvacs.com/shampoo.shtml
this site shows a picture of the piece I'm describing...its the 3rd picture down, called the gauze filter...still its different from the sponge filter....
also...make sure you go slowly with the kirby (and lower it to its lowest setting) if your carpet is heavily soiled....the enzymes in the shampoo are what clean the carpet (oils, grime, etc) and if its heavily soiled the suds disappear almost immediately.
Hope this helps!!!
Feb 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer
On the shampooer tank, remove the screen cap from the little hole that the shampooer hose plugs onto. Clean the screen and make sure that it is not plugged up with debris. Make sure that the screen is securely glued to the cap all the way around the edge. (they sometimes come loose and this will cause the absence of foam) That little (approx. 1 inch diameter) screen is the main ingredient for the foam. The screened cap should fit firmly onto the outside of the little hole in the bottom of the edge of the tank.
If none of this helps, remove the round sponge and look at the holes in the white plastic circle. Turn the on/off foam valve and make sure that the holes open up when the valve is turned to "on". You can purchase and replace the on/off valve if it turns out to be the problem. You can also buy a replacement tank if you're not inclined to mess with it.
If you need another shampooer manual, check out my guide....
Hope this helps...
Marci
Dec 16, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Shampoo-er
It goes on the small hole on the tank where the hose attaches to it. The sponge goes in the hole directly under the on/off valve. Here is a link to my online shampooer instructions.
Marci
Nov 10, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer
You may be missing the small round suds screen. It should cover the hole where the shampoo goes from the tank into the hose. It may be wedged sideways in the hose end.
Marci
Sep 13, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
507 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
