Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Blue screen the code that I received was 0x00000024. I have no idea what that means.
  • twingirl83 Jul 11, 2008
    I have Vista. I have read that it my be the webcam software that I have. This is the third time this has happened in the past two months, and it's really aggravating.
  • 120 Answers
Using your CD use your Recovery Console and do a fixmbr (fix master boot record).
Use your CD for XP, start up, select "R" for repair then select "C" for Recovery Console.. follow instructions and enter password... if no password leave blank and press enter, now type the following ..... fixmbr ..... type "y" to begin and once its done you should be able to start up normally.....
Posted on Jul 11, 2008
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
I'm not having a problem with my tv or the receiver, but there's a blue like that comes on every now and then on the receiver and I don't know what it means? Any ideas?
life_on_stan,
Our Duo receivers do have a blue light which represents the TV2. When that light is on the TV2 is no longer on a screen saver.
I would need more information on your equipment to provide further assistance.
Tommy Faust
DISH Internet Response Team
Jan 18, 2012 | DISH Network Televison & Video
Blue screen 0x00000024(0x001902fe,0xba4eb954,0xba4eb650,0xa88041f2
Blue screen of death usually occurs when there is incompatibility with newly installed program or hardware.. So if you do install something, you may try to uninstall it or remove it on your computer..
Regards.
Aug 13, 2011 | Dell Dimension 2400 PC Desktop
Dell 410 xp has blue screen stop. error code 0x00000024. using my lap top
Follow this Microsoft KB article:
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q228888
If you are not comfortable doing that, you may need to take the computer to a local repair shop.
Jun 14, 2011 | Computers & Internet
My Dell Inspiron E1405 is getting the blue screen of death before starting up windows xp. It has the stop codes 0x00000024 (0x001902FE, 0xF8C7E4D4, 0x0F8C7E1D0, 0x83622816) it tells me to uninstall any...
STOP 0x00000024, 0X0000024, 0X24 or NTFS_FILE_SYSTEM = this stop error means that your NTFS file system is corrupt and this is practically impossible to fix - absolutely everything on your hard disk is trashed. The only reliable way to fix that is to reinstall Windows.
Nov 02, 2010 | Computers & Internet
PC is stuck in reset cycle during boot up. Reaches windows XP screen then powers back down and starts all over again. Used F8, stopped auto re-start and got message ''STOP: 0x00000024(0x00190203,...
Read this http://www.geekswhoknow.com/articles/stop-0x00000024-0x0000024-0x24-ntfs-file-sys-error-code.htm
If you don't have a floppy then you can use
http://partitionlogic.org.uk/   to try to fix the partition.
If you want to recover your files before messing with the failed partition then just boot from a Linux Live-CD and move your files on a USB stick.
Apr 01, 2010 | Computers & Internet
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
Feb 15, 2010 | Computers & Internet
Stop 0x00000024 0x0019023 0x89d97008 0xc0000102
Open up the case. Remove the Memory sticks and reinsert them, if that does not work then you will need to replace the memory sticks
Feb 05, 2010 | Dell Dimension 9200 PC Desktop
Blue screen with error codes
That is probably a disk error, related to the NTFS file system.
Did you try a "chkdsk /f" command to check and fix the disk?
Microsoft has more information on it in the knowledge base.
For further blue screen error troubleshooting check this article.
Jules
Apr 05, 2009 | Toshiba Satellite M35X-S163 Notebook
Won't boot
Here is the cause, and I think you will have to re-install the operating system. Not knowing your machine model number, I have no idea if the operating system recovery is imbedded in the hard drive or not.
If you receive a blue Dell line across the top of the screen during power up, press F11 to see if you can get into the recovery mode. If so, just follow the instructions.
Mar 18, 2009 | Computers & Internet
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
55 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
