Question about Achiever CCS5000 Shredder
Squeaking I bought a used CCS500. It works really great, but makes a horrible, loud, high pitched squeal most of the time. It started infrequently, but now is most of the time. What causes that and how can we fix it?
  • borgesblue Jul 17, 2008
    When trying to shred, there is a loud noise, squeak, like the blades are dry, but I don't know how to open it and lubricate them.
Mineral oil! It worked very well but it took a lot.
Posted on Jul 12, 2008
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
A loud high pitch squeal then the motor will not crank
The starter solenoid may be gone, or it could be something horrible like a timing belt that snapped and destroyed the motor ( not likely). Does the starter click at all when you turn the key. We need more info.
Aug 17, 2014 | 2001 Ford Taurus
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
When driving or starting the car i notice when using the brakes it makes a squeaking noise - not all the time think its possibly damp causing it as it was raining yesterday and it happened but no rain...
To address your first problem squeaking brakes aka "brake squeal", is most often casued by one or 2 things: "Pad vibration" or a "low brake warning sensor".
Pad vibation is usually caused by ineffective pad anti-rattling clips & hardware that allow the pads to vibrate at a super fast speed whenever the brakes are applied, thus causing a high pitch brake squeal. To correct this, replace all the pad hardware and anti-rattling clips and make sure you use a quality pad set that has anti-rattling plates attached to the backs of them. Weather conditions do affect brake squeal, that is why it seems to be worse at times.
Low brake warning sensor squeal occurs when your brake pads reach the point of replacement, the sensor attached to the pads scrapes on the rotor which produces a high pitch squealing sound to warn you it's time for new pads.
As far as your second problem goes (a knocking sound), I'll need more information about the problem before I can offer a possible cause (eg. happens on left or right turns, while going over bumps, at high or low speeds, accellerating...).
Sep 22, 2011 | 2001 Ford Focus
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
2006 Saturn Vue squeaking when I turn the wheel R or L
That sounds like a power steering issue. Does it make the sound when the car is stationary?
Jul 11, 2009 | 2003 Saturn L-Series
2003 Lancer ES High pitch squeal and constant squeak
Shortly after replacing the serpentine belt in my lancer, the same thing happened. It is NOT the timing belt. Belts squeal when they slip. If your timing belt slipped it would cause your car to run funny.
have somebody check the belt for wear (or do it yourself), replace if necessary. If it doesn't need replacement, just tighten it.
If you have the 4cyl engine that I have, the tightening is kind of a pain in the ****. Not a great design by mitsubishi. There's a pulley near the front right corner of the engine in front of the alternator. the belt should be running around this pulley GROOVE SIDE OUT. This is the tension pulley.
To tighten:
1) Lightly loosen the bolt in the center of the pulley (slightly loosen, DO NOT REMOVE).
2) Under that pulley there's another bolt. You can see that the bolt goes through a piece of metal
attached to the back of the pulley. Figure out which way you need to turn the bolt to move the
pulley toward the front of the car. (i don't remember if it's right hand thread, or left hand) This
puts extra tension on the belt. You probably don't need much. Over tensioning the belt can
cause pulley bearing failure. If you haven't done this work before, ask someone for
help
. It's better to tighten a little bit, a few times rather than overtighten once.
3) Don't forget to ReTighten the bolt in the center of the pulley.
If there's lots of cracks and pieces missing on the ribs or grooves of the belt you should replace it first.
Happy repairing,
Cliff
Mar 07, 2009 | 2003 Mitsubishi Lancer
Loud squeaking brakes.
If they are wearing down, they may squeak, and some brakes have a metallic part that will come in contact with the rotor when the wear gets to a certian point making an awful squeaking sound telling you that mabe you should change 'em soon, eh
Jun 17, 2008 | 1995 Ford Escort
Achiever CCS5000 Shredder Logo
268 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
