Clicking noise in rear brakes once pedal brake has depress it going away
Sounds like you have drum brakes in the rear....if so....find a safe place to put your car in reverse and slowly accelerate until traveling about 7 miles per hour...don't try and read you speedometer while driving in reverse...it won't register when traveling backwards...just guess when your at about 7 miles per hour....then slam your brakes on to stop as quick as you can...repeat about 4 or 5 times.
Drum brakes have a self tightening device that is supposed to work it's magic every time you brake while traveling in reverse.
I think your rear drum brakes are lose because you hardly ever drive in reverse, am I right?...I suspect.it is those lose brake shoes rattling, making occasional contact with your brake drums.
If the sound persists after the first 5 back up and stops...try it 5 more times...then test again....if the sound is gone...good...now you know how to fix it when it happens again....
Or... if it sounds like you made an improvement by reducing the noise/sound....repeat the back up and stop thing until it is gone or at a level that seems acceptable....because by being lose and bouncing against the drums...the brake shoes might not immediately be able to be set back to the closest setting....because they were unevenly worn from the bouncing...
In this case....adjust them until no more improvement is being made....then in two weeks....do the back up and stop thing again to set the brake shoes where they should be....now you should hear very little to no noise......but....
If the sound still happens....have a mechanic at a brake shop inspect it....good luck and make sure there isn't any thing laying lose in the car or trunk that will fly when you hit the brakes to adjust the brake shoes....be safe ...find a big open area to do the reverse...then brake hard thing...an open area where no one else is around to get in your way....a place where there are no poles trees or curbs to hit...a place where there is a paved surface to do it on...like a parking lot at an abandoned super market or plaza....chose your place to do it carefully and think about what you could hit or what you could run over before starting....just be safe....
