Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Fireplace Fan Replacement
I have a 36" Marco heat circulating fireplace (the company is out of business) and I need to replace the fan. I do not have instructions for this nor do I know where to look to buy the fan. I live in Racine WI just south of Milwaukee WI. Any help would be greatly appreciated.
  • 4,889 Answers
Well a blower replacement requires some knowledge of electricals. i have found a manual showing the blower replacement. Its not the same model as yours but i think it will be helpful.
12.153.20.72/tech/manuals/108321-01A.pdf
Posted on Jul 11, 2008
  • 6,487 Answers
  • 19,396 Answers
  • Ginko
    Ginko Jul 11, 2008
    Even if factory is out of business, distribution is still active, contact
    Marco Fireplace
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Is the Marco Fireplace 7792778E a fireplace or a fireplace insert?
Apparently the Manufacturer is out of business but there is a MARCO Distribution company. Call them for info since internet searches are failing.
call Marco Fireplace Distribution at 818 764 3366
Jan 02, 2015 | Heating & Cooling
Fan working hot air not coming through front vent
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Feb 08, 2014 | Heat and Glo GFK-160A Blower Kit for Heat...
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
Does this fireplace use a cirulating fan? Model number 794031B
it has a fan as an option safe to use without! fan are located on very back if you look in bottom door, if it is an insert the fan may be located behind a panel behind the logs. if vented through a wall fan is underneath and has a heat sensor and comes on after fp runs for 10 minutes
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
My Heater stopped working on my HEF33 Electric fireplace. My fireplace is only 3 years old not sure what to do.
We have had this same problem with our heater. But I went online to find out where I could purchase replacement parts. The company that sold the fireplace went out of business. I also went on-line to try and fine a universal replacement part. So far no help to be found.
Nov 18, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Problem with HomePride model TE555 fireplace heater
I hav ethe same heater but my coil does not get hot. I am trying to find a replacement part for it but no luck. I called the number (905-847-2643) of the company but no call back.
Jul 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
1,079 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
