Question about Maytag M7DH65B2A Dehumidifier
Shuts off-"full" light when it isn't
My unit will only run breifly (maybe 30 seconds) then it shuts off and the "full" light comes on even though there isn't a drop of liquid in it.
  • ljh208 Jul 11, 2008
    Yes, this unit does have that little rod and it seems to be in working order?? in that I can make the "full" light go off by pushing it. However, when the unit runs on it's own, it shuts off almost immediately.
    Sergeant:
  • 225 Answers
Hi, I'm not familiar with your model but there is usually a plastic rod sticking down from the "roof" of the place where the bucket goes, and this is pushed up by the floating part of the bucket.As the bucket gets full, the float pushes up on the rod which activates the microswitch to turn of the compressor.
With me so far? OK, it could be that the rod is stuck in the "up" position and needs to be pulled down so the microswitch can go to the normal working position.
There is likely to be another mechanism which prevents the compressor running when the bucket is absent, or maybe they are combined on your model. Check that little rod and find out if it moves as it should.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Cheers, D.
Posted on Jul 11, 2008
  • Richard Raynor Jul 11, 2008
    OK, couple more thoughts:
    1/ there should be another item that detects the presence of a bucket - "no bucket no run"
    2/ there should be a humidity sensor which will only run if "dampness" detected- unless you select "continuous operation". If you can see it, check it is not fouled up with fluff
    3/ there should be a removable lint filter just in front of the cold tubes, just behind the inlet grille,- make sure that isn't blocked. The one on my machine (different brand) is accessed by removing the bucket and looking upwards to see the finger grips - it slides downwards into the bucket space to remove it.
    Well, that's 3 things. Let me know how you get on.
    Cheers, D
Unit keeps cycling off and on with the "bucket full" light blinking
It appears as if the water may not be flowing through the hose.
* When you use a hose the unit must be located near the drain. If the hose is to long the water will not flow freely and cause the water to back up in the hose triggering the bucket full.
* If the unit is lower or the hose runs up hill even the slightest incline will cause the water not to flow backing up to the machine
* Hose must remain flat and in a down hill flow to the drain if you are running a longer hose than recommended. If you are have a long distance to run the hose elevate the dehumidifieer by placing it on a stand, milk crate, anything that will hold the unit. Be sure it is large enough and strong enough to support the unit to prevent it from falling. This will help siphon the water from the unit and prevent any water to back up the unit.
* If your using an old hose make sure there are no kinks and water flows freely through the hose. Any kinks or type of pinch in the hose will cause the water to back up
I hope this helps resolve your issue. This is the most common mistake when using a hose.
Nov 30, 2013 | LG Dehumidifier LD650EAL
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
I have a kenmore dehumidifier (about 2 years old), and i've found that after i turn the unit on and it is running for 2-3 minutes, it will then shut down even though no water has collected in the tray. any...
My first thought is that there's not enough moisture/humidity in the air, for the setting you have the humidifier set on. The higher the setting or percentage (i.e. 60%) means that the level you want to maintain. Which may be find in the cod winter months. In the Hot summer months, you want as low a level of humidity as possible (i.e. 45%).
My second thought is that the air intake filter and the coolant coils need cleaning, since it has been used in 2 years. It's just sat around gathering dust and spiders.
And finally, the collection bucket, may not be inserted properly and when the unit starts up the vibration dislodges the bucket just enough, so that it's not making contact with the safety switch. Sometimes when this happens, the Full light indicator will come ON, even if the bucket is empty.
Hope this helps you to start troubleshooting the problem. Please let me know.
May 01, 2011 | Kenmore 54501 Dehumidifier
Auto shut off prevents dehumidifier from working even though there is no water in container.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Dec 02, 2010 | LG Goldstar 30-Pint Dehumidifier
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
May 31, 2009 | Whirlpool AD65USL / AD65USM Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
100 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
