Question about Singer 7442 Mechanical Sewing Machine
Singer Sewing Machine I have thread the machine and everything works when I turn the small wheel in the center of the big wheel. But, when I press the peddle, the big wheel just spins and doesn't move the needle.
    Problem Solver:
  • 18 Answers
Singer has just installed new Q&A features on their website. You can go here: http://new.singerco.com/products and look for your particular model. At the bottom of the product page, you can post Questions for singer experts and other community members to answer!
Posted on Jul 22, 2010
How do I thread the singer 132k6 including the bobbin. is there a diagram i may see
Hope this sight will help if not you may have to contact the manufacturing company for owners manuaql
Jan 09, 2015 | Singer Sewing Machines
Why won't my old manual singer sewing machine needle move?
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Nov 19, 2014 | Singer Sewing Machines
I have loaded my Singer 626 sewing machine bobbin properly, and when I try to bring the lower thread up by turning the wheel, nothing comes up. I do hold the upper thread taunt, so it can 'grab
Make sure your needle is correct for the machine and make sure it is fully inserted and undamaged.
you just hold onto the thread... you don't need to hold it taut.
Jul 28, 2012 | Singer Sewing Machines
I purchased the Singer Futura CE-150. When I click on transmit to machine I do not get any response. I do not get the dialog box to pop up to allow me to sent to machine. I have uninstalled, I have check...
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps
Mar 20, 2011 | Singer CE-100 Futura Computerized Sewing...
How do i thread this? need visual guide please. i can hear something moving, but pedal isn't going up/down.
The "pedal" is the foot pedal and it powers the machine and does not go up and down.
The needle and needle bar go up and down.
If there is a smaller wheel in the center of the handwheel (wheel on the right side of the sewing machine), make sure it is tight. Turn to the right (toward the back of the machine).
You can find threading, bobbin winding instructions and a manual at the Singer Company website.
Mar 12, 2010 | Singer 3116 Simple
Can't get the wheel on my Singer Prelude to turn forward. I can push it back though. The machines not even threaded. What's going on?
Chances are there is a small piece of thread stuck in the raceway area, you need to have a good look it might be very smakk but small enough to stop the machine
Oct 01, 2009 | Singer 8280 Mechanical Sewing Machine
How do i thread my bobbin on my singer merritt 4530
Run the thread around the little silver knob on the top of the machine to the bobbin threader on the top right. Wrap the thread clockwise around the bobbin a few times and then pull the bobbin threader toward the silver bar. If you put your hand on the crank wheel, you will feel a place for your finger to set. Push there and the center of the crank wheel will sideways allowing you to thread the bobbin when you press the pedal. I'm sure my terminology doesn't make any sense.
Jul 11, 2009 | Singer 7462 Mechanical Sewing Machine
I HAVE A SINGER SEWING MACHINE MODEL 2732 AND NEED TO KNOW HOW TO MAKE THE BOBBIN COME UP. I AM LOOKING FOR THE MANUAL FOR THIS MODEL. PLEASE HELP.
When threading your needle make sure you pull enough thread through...a good 4 inches will do..hold the end of the thread and turn your hand wheel by hand until needle comes back up...you should have a loop around your upper thread ...pull this loop out towards you..you should now have two threads..cut threads till about 2 inches and make sure you position threads through the center of your sewing foot and towards the back of your machine. Good Luck
Jun 13, 2009 | Singer 2732 Mechanical Sewing Machine
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
65 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
