Question about Cameras
Mustek camera I plugged in wrong adapter to charge battery,felt camera was getting warm unplugged camera once I felt it hot.Plugged in correct adapter to charge camera now it will not run on ? Can it be that the battery is no good Please HELP
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey mari5,
You have most likely damaged the camera battery and it needs to be replaced. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 22, 2008
Laptop shut down and wont power up
Unplug, remove battery, check for dust in fans and vents, plug in, try to reboot. If it powers up, open Control Panel, Power Options Power , set to High Performance, open Advanced Power settings, set Sleep and Hibernate to Never, Adjust other Advanced settings to your preference. Has it been pulled by the cord? If you have a multimeter check for DC volts at the AC jack plug, that plugs into the laptop. Is the Transformer (brick on the cord) getting warm when plug in? Does the battery charge LED light? Try another cord with the EXACT same power specs.
Jan 23, 2013 | ASUS G73SW3DE Republic of Gamers 173Inch...
No turn on notbook compaq 1711t
Hello The mandatory requirements before you try anything else are the main battery must be installed, it must work correctly, and there must be nothing wrong with the AC adapter or it's connection to the laptop. -Your model is recent enough the main battery must be installed - it won't start up on the AC adapter alone. - The main battery must be capable of being charged up to at least a minimal capacity. - The main battery does not last forever. Typically it works as it should for a year or so then begins to deteriorate - by the second year it can't be charged to anywhere near it's rated capacity. It gets worse as time goes by. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce (you can test for that with a volt meter), and they may get HOT when you attempt to charge them for a while, rather than a little warm, or they may never get warm at all. - If you haven't replaced it since the computer was new, this model is old enough the main battery should be replaced! There must be nothing wrong with the AC adapter or it's connection to the laptop - if there is, the main battery cannot be charged properly. A common thing people do when they unplug the AC adapter is to pull on the cord rather than the plug on the end of the cord as they are supposed to do. Doing that eventually damages the plug and/or the wiring near the plug, and over a longer period of time, doing that damages the jack in the laptop the plug plugs into. The jack in the laptop should move when you wiggle the plug in the jack. Most laptops have an led that lights up only when the AC adapter is plugged in, there's nothing wrong with the AC adapter or it's connection to the laptop, and the AC adapter is charging the battery. That led should come on at least briefly when you unplug the plug from the AC adapter, then plug it back into the laptop jack, even if the main battery is fully charged. The led should not blink on and off randomlyIwhen you wiggle the plug in the jack. If that led never comes on, there is something wrong with the AC adapter or it's connection to the laptop, or the main battery is shorted (check it's voltage). If that led never goes out even after a long time, the main battery is probably no good - replace the main battery. The plug on the AC adapter cord can be replaced, but if you damaged it by pulling on the cord you will probably continue to do that at least part of the time, so since a plug molded onto the cord stands up to abuse a lot longer than a replacement plug, it's often a better idea to replace the cord from the AC adapter to the laptop if it can be unplugged at the AC adapter (a laptop repair place may stock that), or if that can't be done or you can't find that part, replace the AC adapter. The jack on the laptop can usually be replaced but that requires taking apart the laptop and careful removal and replacement of the jack. A laptop repair place does that sort of thing frequently, and often have the more common jacks in stock, though they may have to order one. Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Compaq Presario 1711T Notebook
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Dec 28, 2010 | Computers & Internet
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
My Mustex MP-100
my mp100 mustek player will not switch on or charge up also it will not switch on when the mains charger is plugged in. the light on the charger went out and will not come on anymore.
Aug 12, 2007 | Mustek MP100 Portable DVD Player
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
