Question about Nikon D40x Digital Camera
Nikon d40 autofocus
The other day, all the sudden the camera will not autofocus. I can focus manually, but when on autofocus mode, you push shutter button down halfway and the illumination light comes on without focusing and when shutter pressed all the way, the camera does nothing. r13, when I press the shutter for auto focus. I have reset the camera etc. Problem still exists, nothing happens in auto but works in manual. any solutions?
  • 8 more comments
  • bunkybear Aug 02, 2008
    Auto focus getting stuck, but not all the time: Mine has just started to intermittently do the same thing. No, it's not on Manual or stuck in between, it seems to be the servo that actually twists the focus ring getting stuck. I can hear it clicking like it's trying the work, but it just never gets itself focused. I then zoom out (18-55mm lens) or in, and try again, and it clears itself, and starts working again. Most annoying.
  • Anonymous Aug 09, 2008
    Focus button is set to A, not M. Nothing happens - have always to focus manually with the focus ring now. Is the fault likely to be in the camera or the lens? Can it be cleared?
  • Anonymous Aug 13, 2008
    same problem
  • scott5598 Aug 19, 2008
    As of yesterday, I now have the same problem with ONE of the two lenses for my D40x, the 18-55 mm 3.5-5.6G ED II lens that came with body in the kit. It worked fine for one picture, wouldn't focus for a second picture, started to work intermittently, and now won't auto-focus at all. No sound, no focus movement, nothing! I can still take pictures by focusing manually, as others have noted. The camera is making at least some electrical contact with the lens. If I select "A" on the lens, the camera tries to auto-focus, i.e. the camera sensing light blinks for the distance measurement. If I select "M", no camera light, which is correct. If I switch to my second lens (55-200 mm 4-5.6G IF-ED) everything works just fine! If I switch back . . . the problem returns.
    Well, of the three things that could fail (camera body, less expensive kit lens, much more expensive optional lens), the cheapest piece seems to have died. I'm now going to see what Nikon's "1 year warranty + 4 year extended service coverage = 5 years of protection" on the lens will do for me. Irony: I've only had the camera and the lenses for 13 months!
  • Anonymous Aug 20, 2008
    Yes...The camera works fine for days or maybe weeks, but occasionally, when pressing the release button with my 18 to 135mm lens at max zoom, it will not focus, but if I keep on pressing the release button, it might eventually focus and release shutter. Also,if I change the zoom to some point closer toward 18mm, it will usually start to work normally, and if I use it in manual mode, it works fine. I have returned the camera to Nikon, under warranty, and they returned it to me 3 weeks later with the problem still existing....Any suggestions re what I can do would be great;ly appreciated. Thanks Vic.
  • dan62 Aug 21, 2008
    I have the same problem with my D40 when autofocusing on a surface that has no strong lines, like a blue sky or a white wall. I am quite sure it did work at the beginning and I sent it twice to Nikon France who said there is no problem. I am doubtful. Autofocus works fine otherwise. Am I asking too much from the camera?
  • scott5598 Sep 04, 2008
    Follow-up:
    I returned the lens that would not focus (see my previous post). Nikon repaired it at no charge under the 4 year extended coverage beyond the 1 year warranty. The repair notes: "replace AF gear shaft". I tested the lens and it now, once again, works properly in auto focus mode.
  • gillii Oct 08, 2008
    I have the same with my d40x ( 18-135 dx lens ). on "normal" light and environment conditions it hardly ever happens. my speculation is that there is a bug with the firmware regarding the AF. probably there is a point where the d40 cannot autofocus and hangs. i went with some friends to do some long exposures at night time and it happened every 5 minutes, switched to MF and it was OK. i usually turn the camera off on to solve this issue.
    Gil
  • Anonymous Feb 17, 2009
    Have the exact same problem. Is there any solution?
  • miguel_lobos May 11, 2010
    Same problem here, but with two different lenses, so I think the camera body is the culprit. The switch is in 'A' position on both lenses (18 - 55 mm zoom and 55 - 200 mm zoom), cycling through the zoom range has no effect. two-button reset, menu reset and hidden button reset haven't resolved this issue, I fear the auto focus control system has suffered from some sort of failure in outputting the control signaling to the lens' AF motor.
I have a Nikon D-40 that will not take pictures in Autofocus mode without holding the AE-L/AF-L button. When in Auto mode, the lens focuses, I get the green infocus dot, but the shutter will not fire. I have done a soft reset (Custom Menu) and a hard reset (reset button next to USB port). Same issue. Firmware is A 1.12 B 1.00 . Manual mode works fine. Any ideas?
Posted on Apr 09, 2010
I don't know if I found a "solution" but toggling once the A/M switch on the lens seems to "fix" it every time. By the way, I never had this problem, not even once, in the two years that I had my D50 with the version I lens. If my eyes still worked like they did 10 years ago I would not have given it up for the bigger screen of the D40....
Posted on Oct 02, 2008
  • tmf786 Feb 03, 2011
    hi,
    I had a similar problem until i decided to be a bit more tougher with the lens. sorry if im not technical but i just got mine recently (ebay - defect autofocus not working). I could hear a whir (motor i assume) so i knew there was nothing wrong with the body. as I was on manual and i zoom in then focus ring i could hear it getting stuck. I was a bit more forceful (not too much) when I heard it click. I then switched it to A and hey presto the the auto works. HOWEVER when i leave it on A and the focus ring moves in towards the body it clicks and then gets stuck - i have to then change it to M and unclick it.
I've got the same problem with mine. It went back to the shop, and they sent it back to Nikon for repair. I got it back in 3 weeks. It's been fine since, but I'm always expecting it to break down again. Toggling the focus switch from A to M and back to A sometimes fixed it.
Posted on Aug 22, 2008
    Scholar:
  • 97 Answers
Dan62, your camera will never be able to focus on objects with no contrast. The manual specifically states this. However, you can put the AF marker over something with some contrast, half press the shutter, so that it will focus, hold the shutter button halfway while you recompose the shot, and then press it all the way.
A note to others using the D40/D40X/D60 that are having problems with autofocus: please remember that this camera will not autofocus with mechanically driven lenses. It will only AF with "AF-S" or "AF-I" lenses.
Posted on Sep 05, 2008
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Posted on Jul 21, 2008
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Autofocus problem
Does this problem still exist when you have the shutter pressed halfway down?
Regards,
Worldvet
Jun 15, 2008 | Nikon D40x Digital Camera
Nikon D40 will not autofucus.
Check if the swithch on to your left on the lens set to 'A'. If it is set to M this will be in manual mode and autofocus does not take place.
If this doesn't help, try removing the lens and re-fixing it firmly and properly.
Trust this helps.
Dec 16, 2009 | Nikon D40x Digital Camera
I have a nikon d-40 is there a seeting on it that well let the cameras lens focus when you push the button half way down. I took picture but I had to manual focus I don't know if it the lens or this camera...
Any of the autofocus settings will attempt to focus when the shutter is pressed halfway. What lens are you using? If it doesn't have an internal focus meter, then the D40 won't autofocus with it no matter what. If it does have an internal motor, then check to make sure the lens is set on autofocus.
Check Custom Setting 12. If it's set on AF-On then the shutter button won't focus.
If this doesn't fix it, specify the lens and any other details.
Oct 09, 2009 | Nikon D40x Digital Camera
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Mar 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
Nov 25, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
1,602 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
