Question about Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
My refrigerator is not getting cold
It has not been getting cold at all or shutting off for a long period of time letting the food get warm does it just need freon and how would I go about that? Maytag model MSD2556AEW, side-by-side. Unit is ~ 9 yrs. old. No cold air at all in freezer or fridge, lights are on and I can hear a fan blowing (hot air). Previously I had the problem where the vent between freezer and fridge was freezing over leaving the freezer frozen and fridge warm. This is different as the freezer is now literally hotter than the room. I tried the suggestion I found here of knocking around on the temp control housing, but no luck.
  • 1 more comment
  • shelbymustng Jul 24, 2008
    Same as others, no colling both sides. Nine years old and it is a piece of &%$@. Even if we could get a recharge of it, the ice and water dispenser do not work, the pull handles on the drawers are broke, some of the integral molded in pegs for supports on the liner are broke so the shelves are "wobbly". And then there are the freeze up problems, the drain in the freezer to the evaporator pan clogs with ice so you get water all over the floor. Or the tube that feeds water to the ice maker freezes up so you have to free that up with a heated poker of sorts. Being handy I was able to fix a fair amount without assistance, I pity the person that bought the repairs I mentioned, probably bought the reffridgerator a couple of times over.
  • Anonymous Sep 29, 2008
    maytag performa #ptb19aagr* Less than 10 yrs old. Worked fine until power outage. got power back on, the lights worked as did the fan. however its blowing hot air.
  • gmoneyjessie Dec 09, 2008
    my refrigerators freezer light is on and the fan blows at times but it doesn't get cold at all
  • 101 Answers
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
Posted on Dec 14, 2008
The unit will not turn off on its own.
With all the extra running---are you getting frozen items in the fresh food section?? You have to understand that if the refrigerator was running all the time and for instance had a stuck on temperature control, you would be getting frozen items like lettuce, eggs, etc in the fresh food section. If that is not happening then the refrigerator needs to run until the cold control turns it off. Set both controls to the middle setting and let it run without playing with it for 24 hours and see if it turns off on its own. Frost free refrigerators average run times of 50% to 75% on time depending on how warm the room temperature actually is. If after 24 hours it is still running and some of your Fresh food is freezing then you do have a bad temp control.
Apr 15, 2015 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Wont freeze
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food........
Take care.
Apr 30, 2011 | Turbo Air Freezers
Freezer too warm
Good luck.
Apr 07, 2011 | Fisher and Paykel Refrigerators
Freezer not getting cold
Good luck.
Mar 29, 2011 | Refrigerators
Freezer stopped freezing. food started getting soft on top. power light on. green light off. tapped it , green light on. less than 1 yr old.
Good luck.
Mar 02, 2011 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Ge fridge getting warm
DEFROST CYCLE LASTS FOR 20--30 MINS.AND TEMPS WILL REACH WHAT YOUR READING FOR A SHORT PERIOD OF TIME BUT NOT LONG ENOUGH FOR FOOD TO START TO DEFROST .HOPE THIS HELPS.PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | GE Refrigerators
Compressor runs less frequently freezer warms between cycles
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,,
Mar 29, 2009 | GE Refrigerators
turn up the stat and see is it comming on? (if over 2 years get a new one )
Aug 28, 2007 | Refrigerators
Refrigerators Logo
580 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
