Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony xm1652z amp problems
Ok i have a kicker L7 15 and a sony 1000 watt amp and im havingproblems with my amp. i have it all wired up right but when i turn thekey on the speaker pulses boom boom boom when the volume is turned allthe way down on the head unit. If i turn the amp up it stops and wontdo anything at all if i turn it back down it does the boom boom boomthing again how can i make this stop? i know its somthing with the ampcus i hooked up my friends amp and it works fine thanks
  • 63 Answers
It sounds like you have the high lvl inputs on the amp hooked up instead of the rca's. this will cause the boominess for a few seconds when the amp is on and right when you turn it off
Posted on Jul 13, 2008
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about...
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Mar 18, 2011 | Car Audio & Video
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
What amp will push 2 kicker 15inch cvr's
Hello herb31,
Kicker lists the RMS power handling range of the CVR's from 100-500 watts, with a peak power capability of 1000 watts. There are lots of monoblock amps within that range. It just depends on how loud you want them and how much you want to spend.
In the low range, an amp like the Alpine MRP-M500 will deliver 250 watts to each sub at 2 ohms. And it only costs $179. Currently, the MRP-M500 is out of stock at Crutchfield. I just bought the last one. So my 2nd recommendation would be the Sony XM-1S, which has the same power rating and according to Crutchfield is no slouch either. It's also $179. I really like the Sony, too. It has a small footprint that makes it easy to find a convenient mounting location. Both the Sony and the Alpine are CEA-2006 compliant, so you can be sure that the manufacturer provided specifications are not overrated. Assuming that your vehicle electrical system can deliver the current, both the Sony and the Alpine will deliver an honest 250 watts RMS to each of your Kickers. And 250 watts will make them kick pretty darned good.
In the medium power range, consider either the JL Audio G Series G1700 which delivers 700 watts into 2 ohms. It costs $419 at Crutchfield. Or perhaps the Kicker 08ZX750 with 750 watts at a cost of $399.
To push the CVR's really hard, close to their 500 watt RMS maximum power range, look for an amp that delivers 1000 watts. In this range, you will definitely some heavy-duty wiring, electrical system upgrades, perhaps a 2 farad capacitor, and be ready to spend at least $600 on the amp. Your best combination of power and price would be another Alpine, the PDX-1.1000M, at $799. If you buy one from Crutchfield, they will throw in a 4-gauge amp wiring kit. And if you use a "friend referral code", such as mine, which is p7sdj-hrx8q-9800g, and your order is at least $200, you'll get another $20 discount. And I get a $20 credit toward a future order.
Hope this helps. If it does, please rate as "FixYa".
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
Feb 28, 2009 | Sony Car Audio & Video
HOW TO CONNECT 2 12" KICKER L7 TO A US AMP MD-1D
So you have to run both of the subs to your amp so that its see's 2ohms. The L7's probably have to voice coils to connect both the positive's together and both the negatives together to the positive and negative on your amp
Feb 25, 2009 | Compaq Audio card Sound Card
Kicker l7 dvc 2 ohm wired to sony xplod xm1652z amplifier isnt pushing the sub
it is not the way how get most wattage from your amp. If it is rated to drive a 4-ohm load then it should be ok for a 4-ohm load. If it is rated for a 2-ohm load, then you should not be loading less than that impedance. I recommend a 4-ohm load.
Take note: it is the sound quality from the source that makes up all the total quality of your audio system. If you are overdriving the amps it will give distortion too.
There are many factors to consider when it comes to quality of a car sound system- speaker enclosure design, choice of speaker or driver, equalization, etc...
One more thing, try to get at least no voltage drops if you are wiring the subwoofer amp away from the car's battery.
hope this helps.
Oct 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
127 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
