Question about Garmin GPS receiver mount (900302) Mounting Unit
HOW TO MOUNT GARMIN DASBOARD DISC
I CANNOT MOUNT MY DASHBOARD DISC IN MY VEHICLE, PLEASE HELP
  • kikikoby Aug 16, 2008
    I live in California.
    Becaurse of summer heat ,mounting unit does not stay on dashboard.
    What should I do ?
California nor Minnesota allow windshield mounted objects.
Garmin an a few others sell a device that has an antiskid pad, has shot (lead) for weight so it stays put on the dashboard. It is shaped like a donut, about 8 or 9 inches in diameter. In the center it has a smooth surface so that you can install the suction mount that otherwise would go on the windshield. You can buy them at Wally World or Fry's. Even some of the Worst Buy stores carry them. They are $39.00 however in the first 2 places you can find at around $24.00 to $29.00.
Z
Posted on Nov 02, 2008
My garmin nuvi suction cup gps mount will not stick to my dashboard what will help?
You need a dash disc as the suction mount needs a very smooth surface. Disc are available at GPSNSTUFF.com.
Jul 02, 2014 | Garmin GPS
How do I connect the garmin nuvu to portable friction mount
Hello.
The Garmin Nuvi GPS unit can be taken on the go or set up inyour vehicle. Most units come with a window suction mount that attachesdirectly to your window while some have a sticky dashboard mount. These twooptions can leave permanent marks on your car, with a dark circle on yourwindow or leftover adhesive on your dashboard. Use a friction mount to avoiddamaging your car. The mount uses bean bags to hold it in place withoutdamaging the dashboard.
Instructions
1 Place the friction mount bean bag on the center ofyour dashboard. 2 Snap the Nuvi unit into the plastic mount and set iton top of the bean bag mount. 3 Position the Nuvi at the angle you prefer for bestvisibility while driving. 4 Hold the mount in position and slide the switch tothe "Lock" position. 5 Connect the cables to the Nuvi and you are done.
Thanks for using fixya.
Sep 06, 2011 | Garmin GPS
Does the dashboard disc get stuck to the dashboard and the unit then get stuck to the dashboard disc? There are no instructions for this in the manual. My unit is a Garmin nuvi 255WT.
Yes, the dashboard disk gets stuck to the dashboard. Then the unit gets stuck to the disk.
This is because the suction system used to mount the unit will usually not stick directly to a car's dashboard because of the material or shape, but will always stick to the disk.
Mar 28, 2011 | Garmin nuvi 205W GPS Receiver
How do you mount the disc on the dashboard?
The disk has a very sticky pad on the underside.
Remove the protective film an stick on flat surface.
First making sure surface is clean and dry.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Garmin Nuvi 1300 GPS Receiver
Today I purchased a Garmin Nuvi 1300 GPS system. In unpacking the unit I was able to identify the use of all parts except a small disc that was white on one side & black on the other. The black side...
the disc your talking about, is used to help secure the suction mount when the mount wont secure on its own, like to the dashboard of your car and in some instances even the windshield....
i put mine one the windshield but i do not need the disc for my truck, but not all cars or truck work without it.
the disc will help insure the unit wont fall from where its mounted but like i said, i dont use the disc unless needed.
btw, thats a nice unit you bought.
bill
Dec 04, 2009 | Garmin nuvi 1300 Car GPS Receiver
Hey
they dont give you a home charger with the unit. here is what you should have received
What's in the Box:
  • nüvi 780
  • Preloaded City Navigator® NT for North America
  • MSN Direct receiver with integrated vehicle power cable
  • 3 months free MSN Direct service*
  • Vehicle suction cup mount**
  • Dashboard disc
  • USB cable
  • Quick start manual
the usb cable supplied with the gps will charge your unit using the usb port off your computer also.
i bought a home charger off ebay to save a few dollars but you can buy them off the garmin website HERE just click the accessories tab and scroll the the bottom of the page.
or go HERE for the listings on ebay
Oct 17, 2009 | Garmin nuvi 780 GPS
Garmin 010-10646-00 Dashboard
Garmin 010-10646-00 - The dashboard disk allows the suction cup mount to be mounted onto the dashboard of multiple vehicles.
Read a review as well from one of the customer using the same ....
I use a Garmin GPS unit in my car. The Garmin dashboard disk was the perfect solution to mounting the unit to where I can see it easily while driving. I was pleased to see how easy it was to install and how well it holds the GPS mount in place. I have not yet tried to peel off the disk to see if it did any significant damage to the dashboard covering. I keep cars a long time so that isn't really a problem for me. I do suggest that you find a nice magnetic knicknack to set on the disk when you leave the car parked. Even though you probably take the GPS with you, the knicknack dould possible disguise the fact that you use a GPS and reduce the possibility of someone breaking into the car.
Thanks.
Jun 16, 2009 | Garmin 010-10646-00 DASHBOARD DISK SMALL 2...
How do you use the dashboard disk to mount the GPS?
The idea behind the disk thing (assuming one side is flat and the other has double-sided tape) is for you to be able to mount the disk, with the tape, pretty much anywhere in your car. Once you've found a good spot, clean that area, then peel off the piece covering the sticky tape and stick the disc on to the spot. Once that's done (won't take more than a few seconds), you should now be able to use the suction-cup on the disc (instead of on the windshield).
Either way, that tape is permanent. When they say permanent, they mean permanent. I lived where the outdoor temp was 100+ degrees everyday, and that thing would not come off. Point is, just make sure you mount it where you want it. Just a heads up. :) Good luck!
Mar 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Dashboard mount
I put a little water on the suction cup, and attached to the windshield. Seems to help a little.
Still dangerous. The thing can fall while driving.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin GPS receiver mount (900302) Mounting Unit Logo
247 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
