Question about Onkyo Audio Players & Recorders
Need drive belt onkyo cd player dx2700 - Onkyo Audio Players & Recorders
  • 151 Answers
Best thing to do is ask your dealer to order a belt.
CABLE GUY.
Posted on Jul 11, 2008
Drive belt replacement to open and close cd drawer for Onkyo DX-2700
I have no idea where you are located, but I know this guy has belts for everything, you just need to know the size (or he can look it up).
UNIVERSAL AUDIO VIDEO ELECTRONICS
1137A QUEEN STREET EAST
M4M 1K9 Toronto, ON
Phone: 1-416-461-9899
Mar 01, 2011 | Onkyo Audio Players & Recorders
The door to the turntable will not open and the turntable just keeps trying to change. Had to unplug it to make it stop.
There is a problem with the rubber belt that drives the door of the turn table. Open the cd player and replace the rubber belt.
Nov 17, 2010 | Onkyo Audio Players & Recorders
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
My Onkyo DX 6disc CD changer does not open and close without pulling on the carousel and the unit does not raise or set the disc so it does not play any of the discs now. Is it worth trying to get someone...
Hello: Considering the age of the unit, I would say you need new loading gear belt and mech assembly elevator belt. Look inside for any belts that have become to loose to turn pulleys for gears, take off any belts you find and lay on a flat surface and belts that have become egg shaped need replacing, you might also try buying some rubber rejuvenator liquid from a local electronics parts store to restore grip to the belts but new ones is the best way to go..
Dec 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
DX-C110 oldie
These units have several belts that can stretch or break.
Sep 18, 2008 | Onkyo DX-C340 CD Player
My cd player (model dx-1800) is jammed. When I push eject I can hear the necanism but tray will not open
Hi djhartness
It will have a faulty load belt to the tray assembly. Not hard to replace if this in an Onkyo DX1800. You need to use a belt the same cross section as the one that has failed. If you need any help sourcing the part, just let me know. cheers
regards
robotek
Jul 13, 2008 | Onkyo Audio Players & Recorders
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Onkyo Help needed !!!!
For the belt, you might check out www.mcmelectronics.com they even have assortment sets.
Geno
Feb 29, 2008 | Audio Players & Recorders
Onkyo DX C220
The little drive belt that operates the CD lift mechanism is likely busted. I just started looking for belts now.
Dec 29, 2007 | Onkyo DX-C390 6-Disc CD Changer
79 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
