Question about RCA P61927 61" Rear Projection Television
Will not turn on
When plugged in it makes a clicking sound but will not come on. Fuse is fine. Any suggestions?
    Genius:
  • 2,920 Answers
Blown power supply
Posted on Aug 23, 2008
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
I have a 2004 Scion xB and my right rear signal light isn't working. It's not the bulb because that's working and the click sound sounds off but it wont light up in the dashboard. My left signal light is...
the light in th DASH-BOARD IS out, if you hear clicking & outside is click-g,theres not a fuse,for signals, there is a flasher-relay chk under dash or by th kick-panel or next to FUSE-CLUSTER(BOX), HOPE this helps, good-luck...
May 04, 2011 | 2004 Scion xB
2001 dodge neon key turns no noise no click fuel pump doesn't even turn on, changed steering column out was fine before that.
Sounds like either the ignition switch on the column is not working or you have an ignition fuse blown. Check and make sure the switch is plugged up and have power coming out of it with key on. If no power coming out check the fuses then the switch. should fix the issue.
Oct 04, 2009 | 2001 Dodge Neon
Clicking flashing relay
sounds like a poor connection in the fuse box, or a bad ground.
Jan 25, 2009 | 1989 Chrysler New Yorker
97 silverado won't start
Sounds like you need to get the Starter Solinoid Replaced. Just for Kicks make sure that you check EVERY Fuse and Relay in Both the Fuse Panel inside the Cab and the One Under the Hood.
Jan 11, 2009 | 1999 Chevrolet Silverado 1500
Samsung clicking on and off but not coming on
The bang you heard was probably a capacitor. Since you are still hearing the TV attempt to power on, your power supply and it's fuse are likely fine, but if the capacitor was on the mainboard, the TV would require service unfortunatley.
Oct 14, 2008 | Televison & Video
Will not turn on, but....
the arc when you plug it in is from the degause cirt operating, the fault sounds like at least a pwr supply repair $100, & or vertical + $50,and or horizontal + $150,If water is the reason.
Dec 06, 2006 | RCA 27F650T 27" TV
TV makes clicking sound when power cord is plugged in
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2006 | Toshiba 50H81 50" Rear Projection...
RCA P61927 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
