Question about Samsung Audio Players & Recorders
Only get my speakers to work when the samsung 1200W 5.1-Ch. DVD is on, does not work for TV or game systems
  • 151 Answers
Did you hook up a set of phono cables from tv to your system?If so make sure you have the system set to the right input and sound set to prologic 2.
hope this helps.
CABLE GUY.
Posted on Jul 11, 2008
The screen keeps flashing rear chk and the rear speakers are not making any sound.
I had the very same problem, and found that if you power up the receiver in DVD/CD mode, or tap the function button to display DVD/CB mode, the Wireless Rear Speaker AMP will automatically recognize and turn on the sound. This work around was not posted anywhere in the manual, just 1 of many workarounds I have had to put up with this system to work. Right now my fan went and it just keeps shutting down, I have had this system for about 15 months and very disappointed with the quality. My DVD player stopped working a few months ago, so now the system is rendered useless, not even sure it is worth fixing at this point since it is no longer under warrenty.
Jun 29, 2010 | Samsung 1200W 5.1-Ch. XM-Ready Home...
The back speakers do not work when I watch regular television, only when I watch a movie on the blu-ray or listen to music. How can I fix this?
if you are not watching tv in hd or the show is not recorded in surround then you will not get any sound from them. if this is not the case you can try a simple optical cable run from the tv to the reciever. This cable is about 50 bucks and has awesome quality. Hope this helps.
Feb 26, 2010 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Samsung htz510 wont read dvd or cd? It just says loading for ever and then says error???
I have the same issue, along with a Rear Check issue at power up, and the fan stopped working about a month ago, so three strikes and your out, I would not recommend this product due to the quality. My Oniko was purchased years ago and is still going strong, I moved to an apartment and wanted the wireless ease with the back speakers, never again with this brand. My Samsung LCD is acting up now too, it is only 15 months old, and won't power up right away takes like 5 attempts, unreal
Aug 13, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Cant see screen in Samsung HT-Z420 home theater system
hey man
plug one of those yellow video cables into your TV (in) going from the sound system (out) I've got the samsung Tz 425 but this worked for me before i could hear it on V ipod mode but not see it. now i can just one of theose yellow video cables, it actually says it in book but i missed it aswell
hope this helps
Jul 15, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
My samsung HT-TZ512 home theater
Do what I do for every piece of electronic equipment I own, especially remote controls. Go to the manufacturer's Website and the go to support and download the user manual in PDF format and save it to your MY Documents file or whereever.
Mar 08, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
My dvd home theatre system ht tx75 keeps shutting down
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Need device code for samsung home theater in a box
do a search for the remote brand and device codes, that is what i did with my bose,
Jan 11, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Samsung code for a comcast cable box
The Remote w/ On Demand buttons, it's the same as the DVD player code 1932. Hit the AUX button, press and hold SETUP until AUX blinks and enter 1932. Press the power button and it should turn off the reciever.
*UNLOCKING VOLUME CONTROL* You must until your AUX volume control in order to use your Comcast remote. To do so, you must select AUX, press and hold SETUP until AUX blinks. Enter 9-9-3 and press Vol - (down). This should unlock your volume control when you select AUX. I'm not sure how to set AUX as your default setting for volume, unless you were to program your AUX device as your TV and vice versa I'd suspect.
Hope this helps!
Sep 25, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Samsung ht-tx72 Issue
GEnerally speaking that behavior suggests that the video signal is being lost for a second and returns. The easiest thing to try is to replace the connection cable (video). A bad connection there could cause this although moving the cable should make this happen at will. Check the DVd player on another TV if possible. If hte player is the cause, the "new" TV should show the same symptoms.
The only other possibility is that the DVD player is having a problem generating the video signal. This could be because the disc is not being read correctly (I would expect the sound to be effected as well) or the video processing section of hte DVD player is defective. This wil be a bit more difficult to find.
Can you try the cable and other TV and update this?
Thanks,
Dan
Jul 27, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
133 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
