Question about GE Microwave Ovens
I have a 2002 GE Microwave. Yesterday it started beeping repeatedly and F3 was showing up on the screen. I tried unplugging the microwave, and trying to use it again, with no success.
  • GE Master
  • 9,098 Answers
You have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 11, 2008
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Problem with microwave oven
F3 means a problem with the keypad. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. An exploded view and parts price list can be seen by entering your *entire* model number at the GE parts Web site: http://www.geappliances.com/shop/prts/
Nov 24, 2006 | GE JVM1653 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
