Wharfedale tv key code
When i switch my tv on it just says (Key - - - ). I need to know what i am meant to enter in the dashes. I would be so grateful if anyone could help me.
  • cazzan Jul 11, 2008
    I was trying to set my digital box and went into settings and since then it's asked me for a key - - - , I've tried and tried but got nowhere. Can anyone help me pllleaseeeeeeeee!!!!!!!!
    I would be most grateful.
    regards Carol
  • Anonymous May 12, 2009
    thank u so so much
  • 34 Answers
First try just 0000. That is the default codes for most TVs. If the box is from a cable or satellite company try the last four of your social security number or account number.
Posted on Jul 11, 2008
You press the PP button on the original remote three times. This is also the same button as the green teletext button.
If you have lost the original remote and you have a universal remote which works on the Wharfedale M2126, pressing the button corresponding to the green teletext button 3 times should also unlock it.
Posted on Jan 08, 2013
Press the PP button 3 times
Posted on Oct 14, 2008
  • jjwest Feb 01, 2011
    Guest,your the man or women witch eva,Nice 1;)
I have a wharfedale 64cm tv and it went in for repairs .i do not have the manual for the urc-3415 remote and desperately need the code.please help
Wharfedale 0037, 0556
  1. Press the TV key on the ONE FOR ALL
  2. Press and hold down MAGIC until the red light blinks twice. (The red light will blink once and then twice.)
  3. Enter your (four-digit device code) using the number keys. The red light will blink twice.
  4. Now, aim the ONE FOR ALL at your device and press POWER. If your device switches off, the ONE FOR ALL is ready to operate your device.
  5. Turn your device back on and try all the remote's functions to ensure they are working properly. If the functions do not work properly, repeat steps 1-5 using another code listed under your brand.
  6. If your device does not respond, follow steps 1 to 5 with each code listed for your brand.
May 17, 2011 | One For All URC-3415 Remote Control
Wharfedale 21in tv blue screen with the word key in top corner with 3 dashes please help
You have accidentally activated the system lock or parental lock. This usually happens when 2 buttons are pressed on the remote simultaneously.
You will need to enter a PIN number using the numerical keys on your remote. If you have set a PIN number for this TV you will need to enter this. If not, you will need to enter the manufacturer's default PIN number. This is usually a simple combination such as 000, 111, 222, 123, etc,
I can't tell you the exact PIN number without knowing the model number of the TV. Please try the simple number combinations shown above and post back with the model number if you need further assistance. The model number can usually be found on a sticker on the rear of the TV.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
Lights on the bike flash and the bike will not start, can anyone help?
If you have a factory security system with the sensors located inside the key fobs you probably need to replace your fob battery.
Aug 08, 2010 | 2008 Harley Davidson FLHX Street Glide
My wharfedale tv comes up with key --- how can i
click channel 1000 if you have flow instead ok
Jul 14, 2010 | Televison & Video
Wharfedale key code
Ur tv is lock could be letters or numbers or anythings.Ask the last owner for the codes.Try unplug it for awhile then replug the power,that all u could do.Codes to reset old tv might not exit anymore.
Oct 22, 2009 | Televison & Video
I NEED TO KNOW HOW TO GET AND WORK CODE FOR UET609 UNIVERSAL REMO
n these remote controls any device key can operate other device types because coding is by selecting a number from a list ranges for UET609 - tv: 000-268 and 700-758, vcr: 269-370 and 750-758, sat/cbl: 371-523 and 800-883, aux (cd, dvd etc): 524-699.
As there are 800 codes, select the appropriate device before searching for a code! This presets the start position in the search.
To set a code:-
Press and hold [set], press device key - red led lights. Release keys. Enter 3-digit manufacturer's device code from the list. Led goes out and the code is set. If it doesn't work try another or search.
To search for a code:-
Turn on consumer device!
Press and hold [set], press appropriate device key - led lights - release keys - press [set] - led blinks. Press [power] key repeatedly till device is switched to standby - press device key to store the code. If, after releasing the keys, [set] is pressed twice, search runs backward through the list.
Having found the code, it may be useful to write it down, as follows. Press and hold [set] - press [1] and release. Count and record the number of times the led blinks - release [set]!. Repeat for [2] and [3].
Note! The above information is from the manufacturer of the remote controls. In practice, things may be a little different i.e. on the UK Sagem digibox [power] is digit 1 and the power key is [tv/txt]!
These controls can be regarded as old stock and may not contain codes for digiboxes and DVD drives. However, surprising things happen, if a manufacturer is using old codes. The Goodmans GDB3 digibox can use UET609 sat/cbl code 424 and the Sagem ITD59G can use unlisted code 836.
To repeat, the protocols and associated key codes are referred to by a 3-digit control code, taken from a list of 800. You should find the necessary code fairly quickly - within 100 tries, if you select the correct device type.!
There is at least one more remote control in this series and operation should be the same, though the key layout varies between models.
At times, these remote controls can malfunction.
Red Led stays on - Remove the batteries and re-insert them.
Remote Control suddenly stops operating - make sure correct device key is selected. If necessary, re-enter the relevant device code. If this fails leave the batteries out over-night and re-enter the codes.
Codes: 044,054,119,124,196,198,225,227.
If it works vote for me
Aug 17, 2009 | Televison & Video
I think that this can be a parental control key. if you don't have the key , you can find in owner manual the key which you can use . and if you don't have this manual you can probably try any combinations from 0000 to 9999.
And after all call the company and they will help you .
Oct 20, 2008 | Televison & Video
Can't cancel
Try either "0000" or "1234" and see if that helps...accordianman
May 09, 2008 | Televison & Video
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 26, 2008 | Audio Players & Recorders
Televison & Video Logo
455 people viewed this question
Top Televison & Video Experts
