I am trying to play music through windows media player and the speakers dont seem to be working. i have the volume up to max on both the player and the volume control on the taskbar bar and neither are muted
  • 52 Answers
Your problem are something to do with your audio driver, be sure that you've installed it or you an reinstall to fix the problem, gudluck.
Posted on Jul 13, 2008
Windows media player won't play any audio selections , says can't find files
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
The sound on my firefox browser is low but when I listen to Window media player, it is very loud.
Try following solutions, if it works for you
To switch between speakers and headphones on Firefox,
make sure your headphones are plugged in first,
Right click on volume on the bottom right corner of your screen,
Then select Volume Mixer,
then double click on System sounds,
Click on the playback tab,
then you could switch between speakers or headphones, just select one and click "set default" and OK
only sounds in firefox will play in the headphones,
and windows media player will play on the speakers
You could leave your windows media player to play on the speakers while you listen to firefox videos in the headphones
If you want the media music player to play in your headphones also;
You have to change it in the media player program,
go to options on the media player, then look for playback devices, there should be 2 options speakers and headphones,
just pick one
I usually set the firefox audio to my headphones,
and a media player to the speakers
Please rate & vote if you like solution...
Thanks
Mar 13, 2011 | Computers & Internet
When i play music there's no sounds the media volume is in max and it is not in silent mode.. but when i connect a headset the sounds works fine... Whenever I try playing music on my LG Optimus S Sprint...
check the settings of the player of your.the output must have been muted.so just unmute.if that is not it goto www.mobango.com to download mp3 and mp4 player install it and use it
Feb 03, 2011 | Cell Phones
The sound on my windows media player and itunes dont work
The driver has been deleted. Try reinstalling the driver software.
Jun 14, 2009 | HP Compaq nx6115 Notebook
My Toshiba Satellite has a sounds problem
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
There is no sound and volume on my laptop.
check for the sound for the required audio might be muted
Oct 03, 2008 | Audio Players & Recorders
Problem with max. volume
Not Mac compatible largely.
ALL Mp3 players have a disclaimer telling you not to play it at max volume. Get adjustable headphones to resolve problem
Mar 26, 2008 | SanDisk Sansa m250 MP3 Player
Not sound in windows xp
you need the sound driver you can down load it here
click here
Mar 24, 2008 | Edirol UA-4FX External Sound System
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
