Question about Neff K4316X0 1GB Compact Refrigerator
NEFF FRIDGE KA316X4GB
The door SLAMS shut. How can I adjust the hinge?
  • Ignats0883 Jan 16, 2009
    I have the same problem too. My fridge is behind my bedroom wall so after anyone goes in it all of my lamps and nicknacks shake. It drives me crazy. Does anyone know how to fix it? Thanks.
2 Suggested Answers
SOURCE: neff fridge too cold
Neff have just said to me that the most probable reason is the seal not being tight enough
Posted on Nov 25, 2008
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
Why wright pneumatic door closer v150 slams closed
Adjust the speed. Adjudsting screw in the end of it (on the door edn). Tun it in to slow down, out to speed up. Should only need 1 or 2 turns. If still not adjusting, replace the unit.
May 13, 2014 | Wright Products Heavy-Duty Black Pneumatic...
Door slams open Maytag Fridge MZD2766
Human error may have resulted in the hinges being installed incorrectly. To confirm your suspicion, check a similar Maytag on display in a store.
May 26, 2017 | Maytag MFD2561HE Bottom Freezer French...
Neff fridge door doesn't close all the way
Perhaps your refrigerator is not level.
Jul 14, 2017 | Neff Refrigerators
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
97 dodge dakota driver door sag, repair.
Likely nothing to adjust.
With the door open, see if the door can be lifted up and down while looking at the hinges. If there is play, the door hinge pins/bushings are worn out, and on some vehicles, the hinges are not serviceable, and replacement will be needed. G/L
Oct 02, 2009 | 1997 Dodge Dakota
Fridge door will not stay shut
Glenn,
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
May 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
THE REFRIGERATOR FREEZER DOOR STAYS SHUT BUT THERE IS NO SUCTION AND I AM GETTING ICE CRYSTALS INSIDE THE FREEZER. WHAT COULD THE PROBLEM BE?
there is some thing wrong whit your door gasket, check your door gasket all around and see if is seal properly, if is broken there is places than custom make fridge gaskets. if by any chance you tuck your doors a part, may be than you dint properly adjust the door or you are missing a shim if so.
use some coins to adjust the hinges. buy placing in between the fridge body and the hinge.
place a piece of paper on the fridge and close the door it shut hold the paper all the way around the door.
Good luck :)
Apr 06, 2009 | Hotpoint RLA50 Refrigerator
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Neff K4316X0 1GB Compact Refrigerator Logo
32 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
