Question about Refrigerators
Inlnie fuse? Where about is this fuse located at in the frige???
  • 2,028 Answers
That's hard to tell, they put them at different places within the machines. Usually it will be located under a panel on the back, near the power supply. It will look like a little plastic connector or tube with a wire at each end.
Posted on Jul 11, 2008
U line refrigerator won't turn on. outlet is OK
Check circuit breaker/fuse in back of refrigerator usually located in the rear of the frige behind the panel where the electrical cord disappears.
Oct 14, 2014 | U-Line Refrigerators
There is just 1 little thing standing in between you and your water/ice. It's about the size of a deck of cards and leaves you
thirsty. It's the Water Inlet Valve. This little jewel controls the water
getting into the Refrigerator. When you push the lever it opens to
dispense water. When it goes out you get nothing or maybe a trickle. It also has a valve that controls water to your ice maker so maybe you have water but no ice. Either way you are not happy.
Good News!!! It is an EZ FIX... You can replace this part easily and
probably in less time than you think. Step 1 Find the Make and Model of your Frige and get the Right Part. Step 2 Locate the Water Inlet Valve on your Refigerator. Follow the water supply line to the back of the frige. It is attached to the Inlet Valve. Step 3 Match the new part to the old part. They should look the same and have the same connections. Step 4 Unplug and Shut Off Water to the Refrigerator. Step 5 Mark the wires location on the old part or transfer them 1 at a time to the new part. Step 6 Remove and replace the water lines and mounting screws. Step 7 Turn on water and check for leaks. Step 8 Plug in your Frige and Enjoy. EZ FIX...
on Mar 29, 2010 | Refrigerators
The freezer has stooped working it is the two door at top with freezer at bottom and ice and water not sure of model number.
check the back of your frige you will see the black roud metal under your frige that is the compressor check the overload of the compressor and also check the wiring diagram at the back of your frige see ther if thers an existing fuse in the wiring diagram.
Aug 11, 2010 | Refrigerators
The icemaker is not getting water from the line, but we are able to get water from the front of the door. what should we be looking at?
The water inlet solenoid has one inlet line and two outlets 1 for icemaker and 1 for water dispenser. Located on the back bottom of frige. Unplug frige. Follow water line to part
Nov 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator not defrosting.changed out the control board, thermostat,heating element,and still icing up.
if you replaced the bord on the back of the unit did you replace the 2 thermisters and bottem left back of freezzr loks like a white bullet frige therem is located in left top back of frige under the damper
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Strange noise coming from new Oster 5 c.f. frige...
I did not post a problem with a wine cooler...We all know that problem was caused by the wrong fuse that was installed at the factory.. My question was about the Oster 5 C.F., I did not get any answers...No, I do not want your premium service...I just thought I may get some free insight on my problem...
Dec 17, 2008 | Oster 12-Bottle Wine Cellar - Black
Went Dead
Generally there is not a fuse in a refrigerator. The manual is speaking about your house electric panel breaker or fuse. Plug a lamp into the outlet where you intend to plug the unit in. If you have light there is power at the outlet. When plugged in if the compressor does not try to start it could be the thermostat is bad.
May 31, 2008 | Haier HNSE05SS Stainless Steel
Re: Dispensing water and Ice
the water valve is located behind the frige, remove the lower back panel and follow the water line from the house to the frige as that line meets the frige that's the valve that may be bad,but before you change it, you can test it, remove one of the 2 lines that goes to the side of the frige and push the switch to get some water, water should come from back there, if not re move the other line, it meant that the first line belong to the ice maker, try the other one now, it should give you water. if not replace the valve.
Mar 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
