Question about RCA HD52W59 HDTV Projection Television
RCA 52 inch HDTV
TV has no power to it so it won't come happened very suddenly. From one person turning it off to the other trying to put it on.
  • rebecca197 Jul 15, 2008
    My 52" RCA TV quit working suddenly too. When you pressed the power button, it would come on for 15 sec, make a sizzling crackling sound in back, then shut off. I found out what was making the noise, removed the part, but now no one can tell me where to find this part. Even parts supply stores can't tell me what it is, because the part number doesn't show up in their computers. Can anyone tell me what this part is, and /or tell me where the supposed part number is located!!????
    Genius:
  • 1,139 Answers
Hello Rebecca197,
What part did you remove? and what numbers are you trying to find. post them, and I might be able to do a cross reference.
Thank you,
Hello shainer,
It sounds like you have a power supply problem, check the fuses on the AC board and the check the voltages on the main PS board.
I hope this helps.
Thank you,
Shuttle83
Posted on Jul 23, 2008
We have a 52 inch RCA projection HDTV and today it just stopped working. It doesn't turn on at all. There is no power light or sounds or anything coming out of it. It was fine the night before and when I...
I had the same problem which got fixed today. It was a loose connection to the power supply unit that required some soldering by a technician and cost me 56$. My TV works after 2 months.
Aug 28, 2010 | RCA D52W23 52" HDTV CRT TV
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
