Question about SanDisk Sansa E280 MP3 Player
Sansa e280player turn on problem
Hi, my sansa player went off went it was in use telling low battery. after recharging for an hour also, now i am not able to power it on. It got stuck. can anyone please give me an idea of how to power it on back.
    Problem Solver:
  • 20 Answers
When you plug it into a charger it should power on.
Posted on Aug 04, 2008
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
16gb Sansa player that recharges and plays for only 3-4 hours
let your battery run out by leaving you mp3 player play as long as it can....then open up the back of the mp3 player take out the battery and put the battery a freezer for an out or 2 then let it sit out for a day then put it back in the sansa and recharge it and it should either fix it or help add more life span to the charge
Jun 21, 2009 | SanDisk Sansa e260 MP3 Player
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
My sansa mp3 player
sounds like you are on the right track
let the battery recharge for at least a few hours, unplug and replug the unit to see if you get a response
if you dont get a normal response hit either the reset switch or the reset mode (manual should tell you how to do so) and you should get a response out of it
if you do not have the original manual you should be able to find it on the manufactures website
May 01, 2009 | SanDisk Sansa e250 MP3 Player
Batter low shutting down
Your battery is low, therefore the player is shutting down.
Recharge the player by plugging it into your computer for 3-4 hours - make sure the hold/lock is not activated, or it will prevent proper charging.
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Regarding sansa battery
Battery is rechargeable by plugging into computer. 19 hours is probably not right - more like 8 or 9.
Sansa's website has manuals, faq's and more at:
http://www.sandisk.com/sansa/#/support-0/
make sure you pick Sansa "Fuze" for the m240 series
-Tha Mp3 Doctor
May 24, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e280
Have you tried recharging the battery? If it is not showing when you connect it to your computer, try holding down the Menu/On-Off button for 15 - 30 seconds and see if it goes on.
If you need a new battery this is a good place to get one:
http://www.jr.com/JRProductPage.process?Product=4153711
Feb 04, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e250 PLEASE HELP!
The battery has come disconnected from the charging contacts in the back.
Remove the 4 screws, remove the battery from the back and re-insert it.
Best of Luck.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
