Question about Canon Office Equipment & Supplies
I need to send a fax ASAP and cannot seem to get my fax to work please help
  • marksuz Oct 16, 2008
    Was able to send/receive faxes until I got a new laptop with Windows Vista. Now can't do a damn thing
  • 628 Answers
SOURCE: Cannot fax to an 0866 number
You mentioned one number. The problem doesn't seem to be with your machine. Some fax machines won't communicate with certain others. If your machine works all right with other fax machines, then most likely the one you're having trouble with won't talk. There's little you can do for that problem.
Posted on Feb 07, 2009
My memory is full on my Brothers all in one printer model # MFC - 465 CN. So I can not send any faxes and I'm a buisness owner and needs this fixed A.S.A.P
Hi there!
To be able to send a fax without getting the message that you're out of memory here's what you can do:
-Press the FAX button -Press the up or down arrow key to select Real Time TX press OK -Press up or down arrow key again to choose ON then press OK
Hope this helps!
May 08, 2011 | Brother MFC-465CN InkJet Printer
I KEEP TRYING TO FAX AND GETTING THE MESSAGE. OUT OF MEMORY. HOW DO I CLEAR OUT THE MEMORY ON MFC-6490CW. PLEASE HELP ASAP IF POSSIBLE. THANKS SO MUCH.
The manual for this printer can be found here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc6490cw_all&dlid=&flang=English&type2=-1
If you get an Out of Memory message while faxing and you do not want to delete your stored faxes to clear the memory, you can send the fax in real time:
You can turn on Real Time TX.
1) Press Fax
2) Press up or down arrows to select Real Time TX.
3) Press left or right arrows to select "On"
4) Press OK.
You can now send faxes real time without having to scan the document into memory.
Hope this helps,
Chris
Mar 10, 2011 | Brother MFC 6490CW InkJet Printer
How do you set up the telephone lines for sending a fax
hi, i have the canon jx510p and I cant seem how to change the settings on fax for distinct ring.. I have this fax system ina duet line
Please help
Apr 13, 2010 | Canon PIXMA MX310 All-In-One Printer
HP Photosmart C7180 won't print!! I had an IT person come to my home earlier today, and it was printing when she left. Not 20 minutes after she left, it wouldn't print for me!!! This is the second time...
It would seem that your default 'printer' is set to fax and not print.
When you select print from the file menu it probably says something like HP Photosmart C7180 Fax in the printer option. If it does, go into the printer section from the control panel and make the C7180 (without the fax reference) the default (right click>set as default)
Oct 15, 2009 | HP Photosmart C7180 All-In-One InkJet...
Unable to send fax
I called HP and they had a free solution promptly.
Thanks tho
Apr 08, 2009 | HP Officejet 4315 All-in-One Printer
Dec 19, 2008 | HP LaserJet 3030 All-In-One Printer
Canon mx 700
Plug the line into the L slot, not the telephone one, and it will work.
Aug 19, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Fax problem
For some reason the fax doesn't seem to work.
Need help badly
thanks MMD
May 11, 2008 | Brother MFC-7820N Laser Printer
Error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Oct 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
old marine
old marine
