Question about Kenmore 22422 Top Load Washer
I have a top load kenmore washer that won't spin or drain
It will wash and everything but doesn't make the buzzing noise or anything, just shuts off and i can't get under it because it is full of water. how do i drain the water first then remedy the problem
  • 1 more comment
  • Anonymous Aug 16, 2008
    i have a top load washer that won't spin or drain and its full of water
  • saraheirvine Feb 20, 2009
    top load Kenmore washer, goes through cycle, but won't spin or drain. i took out the water that i could see, but there's more in it. how do I get that out? any ideas of what it could be? is it a belt or the pump? or the motor??
  • antiquern Apr 08, 2009
    I have an older top load kenmore washer model #110.82682710 that will not spin or drain. Finances are tight, can I repair this myself?
Water level does not shot-off
Posted on Jul 21, 2008
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will wash but won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Kenmore 80 Series 23812100 won't spin or drain. I can hear the motor make a buzz, but it never initiates. What is causing this? Thanks. :)
heatman101
Apr 26, 2011 | Kenmore 23812 Top Load Washer
Washer goes through wash cycle but will not drain, spin and buzzs. Time remaining shows in display. Unplugged and plugged back in again and buzzing continue and time still shows in display. Help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My GE spacemaker top loader will not drain, makes buzzing noise
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
113 people viewed this question
Sal De
fordexpert
Robert Rankin
