Question about Fedders A7DH45B2A Dehumidifier
Fedder 65 pint dehumidifier model # A7DH65B2A
I can't get this unit to work. The fan runs but never any water. It is in my wet basement so I know there is a need. Any suggestions will be appreciated. unit runs but doesnt collect any water. have tried different setting but none rork. doesnt ice up and is clean.
    Sergeant:
  • 225 Answers
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry.
Is the compressor running? A running compressor can usually be detected as a deep throbbing from the machine.
If it is running, but not cooling the pipes, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this is usually the cause.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 13, 2008
I would like to know the average monthly cost of using a 65 pint dehumidifier if it runs continuously for 24 hours for about 300 days a year
To find the Annual Energy Cost, look in the Owner's Manual or other paper work that came with the unit. The Energy Star rating paper work will have that information. However, that cost does not include routine maintenance cost or any repairs that may arise from running the unit constantly for 360 days. Sounds like you'll be running it in a damp basement.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Haier 65-Pint Dehumidifier
Unit runs but doesn't draw moisture.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 05, 2010 | Fedders A7DH65B2A Dehumidifier
Dehumidifier runs but does not produce any water.
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Jul 01, 2010 | Fedders A7DH65B2A Dehumidifier
I have a dehumidifier that runs but does not pull moisture from the air in the basement. the application is about 3-5 years old. It is a Maytag and I purchased it at Home Depot. The Model is M3DG30B2A A....
There are a couple of things you can check for and they are; First of all, when you say the unit is running you may only be hearing the fan run. The compressor may possibly be not running(if it isn't running you will have no dehumidification as a dehumidifier is really nothing more than a small airconditioner.(cooling a coil for the moisture in the space to condense to). Second, The space may be to cool for the unit to run and dehumidify well, The space should at least be 65 degrees or warmer. Third, the system may have a leak and it is out of or low on refrigerant(freon). Depending on what you paid for the unit and if it has any remaining warranty(parts only-labor not covered) if the system is out of refrigerant or if the compressor is bad it probably isn't worth the cost to repair.
Nov 09, 2009 | Fedders A7DH65B2A Dehumidifier
Dehumidifier icing up - no defrost cycle
The unit may be leaking freon...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jun 23, 2009 | Fedders A7DH65B2A Dehumidifier
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Dehumidifier
if it does not get cold anymore, then a freon charge is necessary, provided the compressor was not damaged from "left it on for a long time once and found that ice had developed on it. I know that being left on could cause a problem"
Jun 03, 2007 | Fedders A7DH65B2A Dehumidifier
A7dh65b2a
Normal operation, the unit has sensed icing and is in the defrost mode (compressor off and fan on high). When the ice melts normal operation will resume.
Dec 07, 2006 | Fedders A3DH30B2A Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
274 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
