Question about Electrical Supplies
Craftsman Pressure Washer Model #580762250 Serial # 4033531 Need a manual for this particular machine. When it builds up pressure it cuts off.
I believe sears will give you one free;
you have to download it, but it isn't too much trouble, page 16 lists a whole laundry list of possible problems. Word of advice, change your oil in the pump regularly, if it is burnt appearing you might want to consider replacing rings etc and complete teardown, we didn't and trashed the pump.
Posted on Mar 01, 2009
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
My Excell Pressure Washer XR 2750 won't start. I believe it's a timing problem. How can I solve this problem?
You'll need to know who manufactured the motor (Honda, Briggs & Stratton, etc) along with the model and serial number. With that information, you can do an online search for small engine repair manuals and retrieve the specs for you particular motor.
You can even call your local outdoor power equipment repair shop, they'll provide you answers to your questions.
Nov 27, 2013 | Homelite For Excell - Pressure Washer Pump...
hi there, if the compressor built up a 20 psig and run at 1.5 hrs.then stop.check the pressure switch the differential pressure cut in and cut out limit.adjust the cut out to the corresponding cut out pressure you want but not exceed to the designed pressure tank..this will be done on adjusting cut out pressure screw mounted inside the pressure switch.follow the instruction on the manuals adjusting pressure switch.the run time correspond to the cut out limit of the pressure switch. rate my fix if your satisfied thank a lot.
Apr 20, 2010 | Air Tools & Compressors
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
Craftsman 4 hp 2150 psi pressure washer wont start
Go to ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Jan 10, 2009 | Karcher 2500 PSI Pressure Washer
Electrical Supplies Logo
1,075 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
