Question about Norelco Reflex 5811 XL Electric Shaver
Trimmer won't work
Norelco 5811 XL. The trimmer attachment doesn't work. When I open the trimmer I can see that plastic mechanism is moving back and forth like I think it should be, but there is something wrong with transferring that motion up to the metal trimmer itself. Ideas please.
Thanks.
Len
There's a post inside the trimmer that provides a location for counterforce when the teeth move; this is either weak, designed to break after time, or breaks simply because it's not designed to be opened/closed while running. It's relatively easy--if you're patient--to take the razor/trimmer apart and see the problem. A friend and I drilled an appropriately-sized hole through the back of the trimmer at the snapped-post location (which, if one looks at the outside casing of the trimmer is at the bottom of the indented arc), used a dremel tool to cut off an appropriately-sized metal rod, inserted it in the hole, then sealed it with hard (probably model) putty. Years later, it still works fine and--most importantly--I didn't have to buy a new razor.
Posted on Aug 23, 2009
  • fyrewyr Aug 23, 2009
    break after time, or simply because it's not designed to be
    and I drilled an appropriately-sized hole through the finished face of the
    inserted it into (and a little through) the hole, then sealed the outside with hard (probably model)
    There's a post inside the trimmer that provides a location for counterforce when the teeth move; this is either weak, designed to break after time, or simply because it's not designed to be opened/closed while running. It's relatively easy--if you're patient--to take the razor/trimmer apart and see the problem. A friend and I drilled an appropriately-sized hole through the finished face of the trimmer at the snapped-post location (which, if one looks at the outside casing of the trimmer is at the bottom of the indented arc), used a dremel tool to cut off an appropriately-sized metal rod, inserted it into (and a little through) the hole, then sealed the outside with hard (probably model) putty. Years later, it still works fine and--most importantly--I didn't have to buy a new razor.
How do you open the case to replace the batteries? Do the batteries have to be soldered?
On model 5865XL, remove the two screws on the back to remove the back cover. You have to slide up the trimmer to access one of the screws.
The batteries are soldered in. You will find the correct batteries at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 29, 2011 | Norelco 5865 XL Electric Shaver
How many torx head screws to remove cover of 6863xl. Will trimmer need to be removed? Is so how?
On model 6863XL, there are just two screws near the bottom on the back. Remove the screws to remove the back cover. Trimmer will come off with the back cover
If you require parts, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=6863xl
Sep 23, 2010 | Norelco ReflexPlus 6863 XL Electric Shaver
How do I change the batteries in my 6885XL razor
You will find the correct battery pack for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Remove the two screws on the back to take off the back cover. One of the screws is hidden by the trimmer so you must extend the trimmer to see it. Once back is removed, remove the metal clip at the bottom end of the batteries. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Soldering is required to replace the battery pack. If you are not capable of soldering in the new batteries, you may want to consider buying the item below instead for easy installation
http://shaveroutlet.com/philips-norelco-7886xl-quadra-shaver-lower-unit-part.html
Aug 28, 2010 | Norelco Quadra 6885 XL Electric Shaver
How do you re-install the spring on the trimmer? This is for a Norelco 800RX shaver
The spring on the trimmer for model 800RX should not come out. If it has come out from the trimmer, almost certainly the two tiny bits of plastic that hold the spring to the trimmer are broken off. You will not be able to repair this properly...sorry
Apr 15, 2010 | Norelco Quadra 6828 XL Electric Shaver
Norelco shaver 800RX The spring on the pop-up trimmer came out while replacing batteries. Is there a drawing that shows how this spring is attached?The spring isn't broken, I need to know how the spring...
The spring has two coils, one at each end. They need to be pushed, hard, into the plastic tabs. I heard each side 'click' in. I wasn't pushing hard enough at first.
Aug 29, 2009 | Norelco Health & Beauty
How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Jul 25, 2009 | Norelco Health & Beauty
Norelco 6735x trimmer head
Just pop up the top with the cutters. Next pull the cutters from the shaver in the back prongs. Insert the trimmer head and reverse operation when you are fiished. adrianjpater@usa.net
Feb 20, 2008 | Norelco Advantage 6705 X Electric Shaver
Norelco Reflex 5811 XL Electric Shaver Logo
167 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Starnley Johnwells
Starnley Johnwells
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
