Question about JVC KD-G110 CD Player
Chevy Tahoe radio wiring problems
I just installed a sony cd player in my girlfriend's 96 Chevy Tahoe. The speakers worked fine with the factory radio. There are six speakrs in all. Two in the front doors, two in the rear doors and two in the very back mounted to the ceiling. They all worked fine before i installed the new cd player. Now the back door speakers aren't working at all and the ceiling mounted speakers sound distorted. I checked all the wiring at the harness and seems to be correct. What can i do to fix this?
  • danlwelch Nov 09, 2008
    I have the same problem with a Pioneer stereo. I am thinking there is an additional amplifier that I am not addressing properly, but all the wires in the harness are connected.
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Posted on Dec 02, 2008
    Problem Solver:
  • 6 Answers
Based on what u said did you add new wires for the speakers or did u use existing wire, if u installed new wires then maybe somehow 1 or some of the speaker wires is grounded but the most important question is, is your new sony unit pre-wired for 6 speakers out, i don't think so or unless if u added a amp, if nothing was added like a amp or crossover then u just can't hook up extra speakers by simply parallel connection, this where a amp comes in play,2 rca output to 4 or more speakers out, if u just simply connect extra speakers it won't have enough power to power them correctly, see your stock unit has a built in amp to run those 6 Bose speakers, unlike aftermarket units where an amp is most likely used.
Chino
Posted on Mar 11, 2009
  • chino38_1 Mar 11, 2009
    Chino
How to bypass a factory amp on a 2004 chevy tahoe?
You're gonna have to run the speaker wires from the radio directly to the speakers.
Aug 11, 2014 | Chevrolet Chevy Cars & Trucks
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
My cd player/radio lights, info screen lights, heater/ac light and cigarette lighter stopped working, but the cd player/radio still works on my 2005 Chevy Tahoe....how can i fix this?
sounds like it's a fuse issue even tho the radio works,, my vehicle has a radio fuse and a assessory fuse the controls the lighter and lights on the radio
Apr 08, 2010 | 2005 Chevrolet Tahoe
1996 chevy tahoe - radio not working
My mothers 96 Tahoe did the same thing last year. It was a blown speaker in the rear causing her problem. Hope this helps.
Dec 30, 2009 | 1996 Chevrolet Tahoe
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
Nov 20, 2017 | 2004 Chevrolet Tahoe
Sound problems with installing radio in 2001 tahoe
There is 2 harness the one that you are usin wich is the main harness in the second one that normally is conected to power up tha casette deck,there it should be a pink wire conect this wire together with the red one located on the main harness,if you have any problem call me 830 488 2078 im in texas ask for Tony
Mar 13, 2009 | Car Audio & Video
New cd player installed but no sound!!!!!
First be sure thet all wires are properly connected and that the units output sound controls are adjusted (balance & fade etc.)
www.installdr.com has many valueable resources that may assist you.
Good luck
Feb 22, 2009 | JVC KD-G110 CD Player
2004 Chevy Trailblazer radio and CD player works, but no sound
if you have installed a new cd player in there then the propblem could be that your speaker wires and either touching each other or grounding them selfs out.. pull of the cd player and check to make sure all the speaker wires are covered properly and no bare wires are exposed.. if you still have a factory cd player in it then you will probably need to take it to a dealership to have it checked out..
Feb 18, 2009 | 2001 Chevrolet Suburban
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
JVC KD-G110 CD Player Logo
3,598 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
