Question about Fujitsu M4097D IPC Path-Through Flatbed Scanner
Fujitsu M4099D While attempting to scan I get a Front lamp error. Any idea what could cause this? The bulbs and housing are installed correctly.
  • rgk202 Jul 11, 2008
    The bulbs do light.
    Problem Solver:
  • 14 Answers
If the front lamp is correctly installed (take a look at the lamp carrier pictures) and all 8 possibilities from zone48 are OK,
then you have to check the cables.
At the front camera right side you see one wide black connector for the CCD data transfer cable and one grey plug for power.
Inside the CCD cable there are 40 coloured wires.
Power plug test:
Use a voltage meter to check the power. In some cases the soldering points at the PCA are broken or the plug pins are burnt.
CCD cable test:
Disconnect the CCD connector at the camera.
Disconnect the CCD connector at the scanner's backside at the junction board.
Screw off the metal cable clamps.
But the two connectors side by side.
Now use a resistor tester and measure from connector contact number 1 to contact number 1 at the other connector if there is a linkage. Then do the same with contacts number 2 and so on.
A lot of work but a must.
By a broken wire you will get no linkage.
In case you found broken wires you need a new cable.
Fujitsu part number: CA04315-F851
Fujitsu part name: CCD Cable
Posted on Jul 16, 2008
  • 25 Answers
First, you didn't say whether the Front lamps are actually lit. I know that it is difficult to tell on this model unless you cheat the lamp interlock switch and fire up the unit into scan mode.
Front Lamps errors can also be generated by a loose front camera cable. There are no dedicated lamp detectors. The 4099 uses the camera's ccd's to detect if the lamps are burning. It is also possible, but less likely , that the lamp fuse on the main board (slides out from rear) is blown. (Fuse part number CA53004-0227).
From previous experience, there is probably a 95% chance that the issue if coming from a loose front camera cable. Not the kind of thing to get in and check unless you are service savy. I have had several calls that drove me nuts with this issue until I reseated that cable onto the camera.
The Fujitsu service manual list these possibilties :
a. Do the Front side lamps lite up when you attempt to scan?
b. Is the lamps correctly seated?
c. If the lamps don't light up, possible lamp inverter problem or fuse problem.
d. Is the glass surface and white sheet guide clean?
e. Are the connectors at the front camera ccd loose?
f. Is the power supply output normal?
g. Possible front camera failure.
h. Possible connections from camera to the Rom board problem.
Posted on Jul 11, 2008
The scanner is reporting an E2 error code when it draws a document in. Any ideas? Re-cycling the power clears error but comes back when I scan. thankyou in advance
This error message means ADF front side scanning optical alarm (lower optical unit ADF) which indicates ADF (front) lamp intensity check. Please follow the steps provided below:
1. Is the upper glass (white sheet guide)of the reading section dirty?
Open the ADF, and clean the sheet guide (white part) and the glass.
# When operating the scanner, the ADF’s inside glass becomes very hot. Take serious caution as the heat can cause burns. Before you clean the inside of the scanner, turn off its power and unplug the AC adapter from the outlet and wait (at least three minutes) until it gets cold.Be careful not to pinch your fingers when the ADF cover is being closed.
Note: Cleaning should be done approximately every 10,000 sheets scanned, though it may vary depending on types of
documents scanned. More frequent cleaning is necessary when the following types of documents are scanned:
- Smooth surface document such as coated paper
- Documents printed on almost entire surface
- Documents processed with chemical materials such as carbonless paper
- Paper with a high calcium content
- Pages with pencil lead
- Document where toner is not fused sufficiently.
If the above does not help, then the issue is caused by any of the followings for which you may have to contact the Fujitsu Expert/Engineer.
1. Lower Optical unit ADF may be dirty.
2. Lower lamp may not be functioning properly.
3. The connecting cables might be damaged.
4. The connectors are not connected properly.
Hope the above information is helpful.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5750C Flatbed Scanner
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Fujitsu fi-4340C changing the bulb
Open up the ADF ****.
Remove Two Silver screws holding front
of top cover.
Remove screw from ADF release button.
Pull back of top cover to unclip.
This will enable you to see the rear lamp bay
and camera unit.
Lamp is situated under Camera unit.
ADF = Auto Doc Feeder.
Jun 09, 2009 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi 4750c scanner error
Try a flatbed scan scan with the cover open.  If you see the lamp come on, it's likely a cable or CCD problem, though it can be caused by a really dirty reference strip or mirrors. I've never seen one that dirty but it's mentioned in the service manual. I have seen lost documents in the ADF unit cause backside optical alarms, but the front unit is protected from this by glass. If the lamp doesn't light, it can be a defective lamp or cable. In all these cases, you'll need a tech onsite. Disassembly of this model is difficult & reassembly is even worse. I wouldn't recommend it even if you're mechanically inclined.
Apr 07, 2009 | Fujitsu fi-4750C Flatbed Scanner
M4099d scanner
Attributed to paper sensor problems.
Clean the little square and round paper sensors under swing arm of
upper feed roller asm.
also clean the clear plastic return reflectors.
these may need changing as they taint after time.
Jan 12, 2009 | Fujitsu M4099D/FI-4990C Scanners
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Fujitsu M4099D
What resolution are you at? When scanner manufacturers rate their scanner at a given speed, it is usually :
1. at 200dpi or lower
2. landscape mode
3. plenty of ram on the pc
4. most image enhancements turned off.
If you are running at 300dpi, you scanner will slow down considerably. You can set this is your software, but also check thru the front panel.
You probably won't get 90 ppm in reality, just as you usually won't get the gas mileage posted on the new car sheet ! But you should get at least 70ppm.
Check your operator's manual to access the front panel menu.
Jul 29, 2008 | Office Equipment & Supplies
Fujitsu M4099D
The Rom board is the big circuit board that can be removed from the rear of the scanner. I think there are about three screws that secure the plate that surrounds the output jacks. With the screws out, the whole rom board comes out like a sliding tray. The fuses are round and brown in color. BUT warning! Don't mix them up because they are of different values. If you try swapping them around, you will put the wrong value in another slot and it will blow! If your lamps are lit, then the fuses are ok, but try pulling the circuit board tray out and reseating the tray.
If the lamps are lit, then the fuse and lamp inverter is ok. If you swapped the cameras, and the problem still says its the front lamp, make sure that the lamp is turned around to its proper position. The lamps are masked with a clear opening. If that opening is not turned to shine the light at the right position, you could be getting the alarm because of the loss of light.
If the problem shifted to the rear lamp alarm when you switched the cameras, then the camera mirrors are real dirty inside or its just a bad camera.
Jul 11, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Fujitsu M4099D
Sounds then like a loose camera cable , dirty glass, or white background plate.
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Fujitsu M4097D IPC Path-Through Flatbed Scanner Logo
492 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
