Question about Canon PowerShot A640 Digital Camera
Canon powershot A640 wont turn on
There is rust on one of the terminals in the battery compartment. I think this is the reason for no power. Can you give me advice on how to clean it?
  • weezie717 Jul 14, 2008
    My camera still will not power on!!!! I have tried the steel wool, yes, it did clean everything up, but the camera still won't turn on. What else could be wrong?
    Do you have an estimate of how much this would cost?
  • Canon Master
  • 1,879 Answers
Greetings,
Better contact Ritz Camera or a local camera repair shop for pricing details.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 15, 2008
  • 4,234 Answers
If the rust in the compartment is from a leaking battery, then usually cleaning the contacts takes care of the problem. If the reason for hte rust is that the camera got wet, there is likely corrosion inside the camera that will not be fixable other than to replace the boards. Typically, this will be more expensive than replacing the camera.
The unfortunate part here is that Canon doesn't provide anyone other than authorized service centers with service information. The parts will be available only to those serice centers. Try calling one to get a rough estimate.
I don't think that there is much you can do with this camera yourself.
Dan
    Champion:
  • 217 Answers
If the rust hurt the camera that bad, I would just recommend buying a new one. Repair costs are ridiculous.
  • Canon Master
  • 19,396 Answers
Use circuit cleaning solution Like this ones
  • 790 Answers
Hi
clean the battery terminal with laquer thinner to removed the rust then check your battery if it is in good conditon,,, but if the terminal is clean and the battery good conditon! and no power again, maybe the battery terminal wire is affected of rust maybe this is open wire or no connection in the battery terminal!
Thnaks!!!
Posted on Jul 14, 2008
    Novelist:
  • 126 Answers
Take the battries out then sprinkle a little backing soda in a small dish and with a small brush dip the brush into the water and dabit into baking soda now dab the brush with baking soda and water on it on to the contaminated rusted spring this will positivley netrualize the acidic rust and old battery acid. next put in a new barrery in
  • 2,427 Answers
Did a battery purge(explode) inside it ?
If it did or was corroded for an extended period then the copper contacts might have been broken inside the camera(part that connects to the circuit) If a batter purged then the damages may have gotten in further
If cleanin the outside didnt solve the problem then its diffinately broken inside or the problem is far worse. In any case the camera will need to be opened and serviced. If you have the time and knowledge then by all means give it a go if not then i suggest you send it to a service technician in your area
    Genius:
  • 2,035 Answers
Clean the rusted surface till you see the metal and make sure there is no rust on the surface , this could be caused due the battery leak in the camera ,please check the batteries periodically even its not used....
Posted on Jul 11, 2008
    Genius:
  • 2,028 Answers
If there is noticeable rust on the terminal, then there is more than likely rust and corrosion on the inside as well. Take it to a camera shop and have it professionally cleaned. They will open it up and clean it inside and out.
  • Canon Master
  • 13,433 Answers
" If the corrosion is small use the eraser at the end of a pencil. There used to be some pens with erasers, those were better because they are a bit harder. Otheerwise some vinegar in a q-tip works very well. Just remember to dry it or let it evaporate."
    Master:
  • 555 Answers
Steel wool should rub that right off.
My canon powershot A640 wont turn on despite having new batteries installed, also the USB connector socket has fallen inside the camera, will this cause a short that will stop it powering
Yes, you are probably right. A short within the camera could make it "un-startable. Take it to a local electronist or a Canon dealer and they will help you solve this problem. Also check if the batteries are good and fully charged. Some new batteries could be faulty from the factory.
Apr 07, 2010 | Canon PowerShot A640 Digital Camera
Canon PowerShot A640 lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2009 | Canon PowerShot A640 Digital Camera
I have a canon powershot A640 when you press the on button it wil
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Canon Cameras
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Jun 16, 2008 | Canon PowerShot A640 Digital Camera
Try turning the camera on and pressing the DISP button once (button in the lower left corner).
Mar 09, 2008 | Canon PowerShot A640 Digital Camera
Canon PowerShot A640 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
