Question about Asrock K7S41GX Motherboard
Mother Will Not Post
When MB is powered on the CPU fan spins and nothing else happens.
I have placed a PCI PC Analyser card which displays the POST CODE and only displays EF.
I have removed everthing from the MB apart from the CPU and reset the BIOS but results are still the same. I have also used a different PSU.
The CPU is a AMD Athlon XP 2500 (Barton).
This is my second MB as the 1st one also gave me the same results.
Please can you help?
  • 1 more comment
  • Alan Jul 12, 2008
    Hi 8bytes,
    the MB is a ATX (20pin connector) Asrock K7S41GX.
    I am going to try another CPU and will post the results here.
  • Alan Jul 12, 2008
    OK.....I have put a AMD Athlon 1800+ and the MB has posted !
    So the CPU must be shot!
    I have checked the BIOS version and it is the latest for that MB, Version 2.80.
  • James Grady May 11, 2010
    Is the motherboard "AT" or "ATX"?
Replacing the CPU has resolved the MB not posting.
So, from my findings the other CPU must have been faulty which was bought 2nd hand from ebaY!
Is there a way to test it?
Thanks for all advice,
Posted on Jul 14, 2008
  • 23 Answers
Your post code EF comes from EF Configuration memory error - can't find memory Derives from AMI BIOS and uses port 80h
The memory failure is normally due to the first bank of ram or a data line
Check to see if your ram is seated properly, that is make sure the ram stick is in all the way down. Your problem is your system can't find RAM
Posted on Jul 13, 2008
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
I have been tasked to fix an Acer M3802 just out of warranty. It will not post. I have pulled all perifrials, USB, SATA, WNIC, and Vid card. Fires up fans spin - no post. I reseated proc with new arctic...
Either a MoBo or CPU problem. Do you not have a post analyser that plugs into a spare PCI slot? You could then start from bare bones and progress through or at least know it was the CPU or MoBo quicker.
Jan 06, 2011 | Acer Computers & Internet
Computer does not post. Fans & lights on.
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
Oct 13, 2009 | ASUS A8N32-SLI Deluxe Motherboard
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
It's turned into a brick! I repaired a loose power connector and put the unit back together and voila! instant hi-tech door stop! The power connector now works fine; when I hit the power button the LEDs...
Hi there
The only thing i can think of is to plug a post card into you micro pci slot and let that do the hard work .!
strip and reassemble checking every connection cpu seating and lenth of screws in right places i have had it previous that wrong lenth screws in wrong places can short out and cause all sorts of problems and damage.
Regards AL
Jun 29, 2009 | HP Pavilion N3295 Notebook
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Hello Arua
I would suggest you get your hands on a 4 digit post card to diagnose the problem
heres one
  • Determine defects by difference sounds coding with build-in speaker.
  • It can diagnosis the motherboard signal which show the problem of CPU, Memory, video card, etc.
  • The POST code display is made up of a dual, dot matrix hexadecimal read-out that display's Power On Self Test (POST) status codes
  • Support the power source working indicator -- +5V,+12V,+3.3V and 12V(When indicator LED is on to indicate its respective power is fine, otherwise to indicate its respective power is failure.)
  • Fully compatible with any kind motherboards which has the PCI and ISA bus slot.
  • If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
    on the ask me button, I will ansver in most cases within 24hours.
    Thanks and good luck!
    May 05, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    T2615 E-Machine
    Sounds like mb is not posting,
    remove all cables to drives,
    remove all cards except video , re-seat video.
    remove all external devices keyboard,mouse , usb etc...
    remove all but one stick of memory
    re-seat the cpu
    power up and if fans all turn and still no post then power down, clear bios jumper , swap memory
    if fans turn and still no post pull memory ,power up does it beep,
    if it does memory may be blown.
    swap video card or cpu
    at some point you wont be able to swap much without extra parts or help.
    Apr 26, 2008 | E-Machines eMachines Desktop PC
    When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
    Nov 07, 2007 | ASUS A7V8X Motherboard
    Asrock K7S41GX Motherboard Logo
    114 people viewed this question
    Top Asrock Computers & Internet Experts
    Computer Links
    Iqbal Husain
    Iqbal Husain
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
