This problem is called as horizontal display problem, caused from dry soldering and also due to failulre of horizontal display controller resistor and IC .So locate for dry solders,if there is no dry soldered components,replace horizontal display controller IC. It will Solve your problem.
I think it helps.Let me know
All electronic components(resistors,capacitors,IC) are fixed to PCB(Circuit Board) with a silver color metal component called as soldering.In several cases these silver color metal get separated from component and PCB ,then it is known is desoldering. So soldering is connecting point between PCB and electronic components.
Ya...deffinately! Because when components are cool it work normally but after certain time there is evolution of large heat from faulty component,it will cause problem.
An other suggestion can be this, but what's the cause ? television is standing on a too sunny place or a too wet cleaning of the screen another reason bad materials or to thinny fcc connecting filmsheets read this http://itstillworks.com/causes-horizontal-lines-lcd-panel-37988.html and Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted... LCD screen repair
What do you mean by dry soldering?
what do you mean by dry soldering?
I turned the tv off for a while and then turned it back on. It is working fine again now.Is this normal with the problem you stated?
Thank you!
