Question about Maytag Kitchen Ranges
My display says 5ab on it I cant get the oven to work or any of the oven displays to work
  • etheringtonl Nov 28, 2008
    have SAB message on stove. can't reset, need manual to reset
We just had the same problem and fixed it. Just continue to hold the Time button until it starts flashing and then it will be active again.
Posted on Nov 02, 2008
  • 413 Answers
The code is actually SAB meaning "Sabbath Mode". Refer to your owners manual for turning off this mode by entering a series of button presses. If unsuccessful, the electronic control may have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 12, 2008
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
Control panel
The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Jun 18, 2013 | Maytag 30" Built-In Single Electric Wall...
The digital display for a Magic Chef gas oven reads "5 A6", what does that mean?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
Mar 21, 2013 | Kitchen Ranges
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
My gas range display changed to "5Ab" and does not work anymore.
You are set to Sabbath mode.
Try holding the clock button in for 5 seconds and that may correct it.
Mar 10, 2009 | Amana RanARG7302 Gas Kitchen Range
Kitchen Ranges Logo
241 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
