Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Not cooling I have a kenmore 363599522996 that is not cooling in the fridge section. The fan is running, compressor runs, there was a ton of ice frost on coils and i defrosted all that, timer and heater seem to be working fine but fridge is still not cooling. I can feel air coming out of vent in fridge but fairly weak perhaps. (I don't know how strpong it should be). THere is no obstruction in vent, How long should it take for fridge to cool down after it has been off? I appreciate any help! thanks.
  • 943 Answers
Hi Thanks For The Question. The Problem You Are Having Is With The Defrost Thermostat. Replace It that's What Caused The Ice Build Up. A Fridge Will Take 24 Hrs To Work Properly. Also Clean The Coils AT The Back. Thanks The Appliance Doc
Posted on Oct 03, 2008
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
12 yr old kenmore top freezer. Freezer get real cold but does not freeze. Fridge part does not get very cold. I cleaned all the dust from coils, fan runs and all the seetings are good.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
Model: 253-54743301 Kenmore Refrigerator\r\nlost cooling in both Refrigerator and Freezer
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jan 07, 2011 | Kenmore Refrigerators
Refrigerator running but not cooling
Check list:
fan motors all functioning
Cooling coils free and clean
Compressor cool to the touch
(compressor blazing hot bad relay)
Backside of freezer section frosting up
(bad defrost heater,thermostat,or timer)
Small line from compress is HOT
(cool high pressure line means low charge)
Suction line frosting up (overcharged)
Generic ice box Training manual
May 17, 2010 | Kenmore Refrigerators
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Dometic RM763. Freezer=Yes,Fridge=No
Aug 21, 2009 | Refrigerators
Kenmore Refrgierator is not cooling enough
Is the frost on the entire surface of the evaporator or just a portion. If it is only frosting on a portion there is a possibility your system has developed a leak and has lost some of the charge. Or your compressor has lost its ability to pump the gas. A bad condenser fan motor overtaxes the compressor and can cause premature failure. If it is a bad compressor it may be time to replace the refrigerator. Replacing the compressor is an expensive job and the warranty is only one year on a replaced compressor.
May 31, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
110 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
