Question about Citizen GSX 240 Matrix Printer
Printer not Detected
I have changed already my CPU into Pentium 4. Now, my problem is that, I can't print because the CPU can't detect it. What will I do?
Solution about printer not detected??????
Posted on Jul 17, 2008
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
I have Konica Minolta bizhub 350. My computer is already detected bizhub 350 but not print Thanks
When your computer has detected the photocopier machine, then the next step is to install the drivers, which you may find in CD-ROM or you can Google it.Drivers are easily available on the internet.Download the drivers, Install the printer and then execute print command.It will surely work. If you want to use it as a single pc printer then its ok, if you want to use it over network, as a network printer, then you have to assign IP address to machine.
Mar 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Sound card is not working
install mother board drivers. if already installed see it in see it in system device manager hard ware and see if the hard ware is detected.
if there is a yellow ? the driver is not installed, if its disabled enable it and lastly if the sys tray shows a volume speaker like icon and has a x on it ..it means sound is muted. or lastly volume kept so low as then no sound will be heard please check this all
Sep 19, 2009 | Dell OptiPlex GX270 PC Desktop
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Printer MP160 service error 5010 after refill catridge
I had refilled the catrige, then when I start to print a 'service error' window will appear. At the LCD screed shows E.. 4 ..2. I believe the printer simply assume the catridge is depleted, but how can it happened as I already just refilled it.
How to make printer detected the catridge as a full? I really hope you can solve and make my refilling mission succesful and my printer work again.
Aug 13, 2008 | Canon PIXMA MP160 All-In-One Printer
Incorrect Port Detected
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Jun 08, 2008 | Lexmark X3550 All-In-One Printer
Not printing
hi sand;
you may try cleaning the copper in your cartridge with tissue paper and also the pins in the printer but do it slowly, and see if it works
thanks
Jun 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Citizen GSX 240 Matrix Printer Logo
98 people viewed this question
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
jay kaye
jay kaye
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
