Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes. As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time. If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
