Question about RCA HDLP50W151 50" Rear Projection HDTV
RCA DLP 50" NO PICTURE
I DON'T KNOW IF MY LAMP IS BAD AS LIGHT ON FRONT PANEL DOES NOT WORK. HAVE SOUND, NO PICTURE. CLICKING SOUND FROM LAMP BOX.
  • 1 more comment
  • jim0204 Aug 16, 2008
    i get no picture the green light flashs 5 time thay told me it waws the bulb i put a new bulb in and still have the same thing now thay say it the ballas can you tell me where to fine this and is it someing i can fix
  • chawlaps Aug 28, 2008
  • Anonymous Jan 10, 2009
    i have aproblem i have no
    calgary local chanel
MY 50 in RCA TV is making a clicking sound and there is no picture or sound it doesnt even seem to turn on i dont know what the problem is can someone pleace help
Posted on Jul 29, 2008
Hoping it's just the lamp - removed it, and it had blown, broken glass and all!
Posted on Jul 12, 2008
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
Good morning, i have a 50'' rca hdtv rear projection.../ and when i turn it ''on'' there is no sound and no picture..but the blue light comes on and then blinks 4 times and the 5th time it stays on then...
You might have a bad lamp. RCA DLP projection That is the most comon problem with them. CRT rear projection, Red,Green,and Blue tubes.If it is the silver one w/the black speaker grill. Chass # _ _ _222 ?
Has 222 in the number.Can be several problems. Many things go wrong in those. Horz. Output,Flyback,And bad soldering are the most common problems w/those. Recomend staying away from RCA. Not the same company they once were.
Jan 01, 2010 | Sanyo DP50747 50 in. Plasma TV
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
My 50 inch rca dlp tv will not turn on... the power light comes on but no sound nor picture. we had the bulb replaced about 6 mnths ago and and i know its not that. any suggestions?
Dont be to sure about LAMP,I have seen where NEW lamps can take nose dive, But try Ballast board that fires up Lamp,if it is Bad Lamp will not fire.
Aug 19, 2009 | RCA Televison & Video
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My RCA Scenium 50in. is not turning on!!
Its sounds as if the lamp has exploded or the color wheel has. I will post a link to a site that has a trouble shooting manual on CD called RCA DLP Disc #1 which covers every DLP in the ATC line which is what your model is. They have it either in cd form or they will email it. Its a very good resource for fixing your own set.
http://servicemanuals.vstore.ca/
Jun 16, 2008 | RCA HD50LPW175 50" HDTV
Rca HD50LPW62YX1 50 in. DLP TV
Try lamp first #265919 Approx $300. Use ONLY RCA LAMPS from a RCA box
Dec 14, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
No picture
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
Oct 25, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
680 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
