Home | Digital Cameras | Door of the Battery com...
Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Door of the Battery compartment
By lhr28 on Jul 11, 2008
Door of the Battery compartment broken
Same Problem
Jan 21, 2009
-   Battery door wont shut use the tape solution - please advise where I can get a new door?-   andy1kerri
Jan 17, 2009
-   Same here - I would have thought someone would know where to go to get it fixed?-   Guest
Jan 06, 2009
-   Chipped battery door means I cannot keep closed (other than using tape). Where can I get repaired please.... or is it simple to just obtain a spare part. Txs. -   xxDamoxx
Dec 21, 2008
-   I've been using good old duct (duck) tape. Its silver so matches and holds well and easily replaced. But I would love to find a replacement cover instead. -   jw2base-3
Dec 15, 2008
-   I also got the same problem as battery door cover broken and need part for replacement.-   Guest
Best Solution
posted on Mar 10, 2009
Very Helpful)
tomlenart
Rank: Apprentice
Rating: 100%, 3 votes
To buy a replacement battery door is easy - go to Ebay - buy the replacement or, for the same price (around $20), buy an old camera just for the sake of the door. The second part, replace the door is much more difficult but I found out how to do it. The door has a hinge (a 1 inch long pin) which needs to be slid out from the camera to take the old door out and then to insert the new door. However, this pin just comes out if you open up the camera. To open it up, you need to remove 6 screws with Philips precision screw driver 1.6 mm ($7 at Radioshack) - there are 2 screws on 3 sides of the camera. After removing these screws carefully separate the two parts of the camera - you just need a gap of (maybe ) 1/16, just enough for the pin to slide out, which can be done forcing it out with a sharp knife. After the pin is removed, remove the old door, put the new door in place, put the pin back and use some pressure to join the two parts of the camera together. They join back with a click, put the 6 screws back and it is done.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 19, 2009
Not Rated)
tsbdj09
Rank: Apprentice
Rating: 0%, 0 votes
Same problem...just called Kodak. They don't carry the replacement battery door for the CX4230 anymore. They referred me to http://www.uscamera.com where I ordered it for just over $11.
Was this helpful?
Yes
No
Solution #3
posted on May 23, 2009
Not Rated)
Pluma
Rank: Apprentice
Rating: 92%, 10 votes
You can buy the battery door and instructions on eBay.
http://cgi.ebay.com/gENUINE-Kodak-C330-C-330-Battery-Door-PHOTO-INSTRUCT_W0QQitemZ190308553794QQcmdZViewItemQQptZDigital_Cameras?hash=item2c4f461442&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
Was this helpful?
Yes
No
Solution #4
posted on Apr 25, 2009
Not Rated)
OZwombat
Rank: Apprentice
Rating: 96%, 6 votes
I had this problem (Picture 1) but the chipped lugs were on the camera body where they meet the lugs on the door so replacing the door was not an option.
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
Was this helpful?
Yes
No
Solution #5
posted on Feb 17, 2009
Not Rated)
Whassupwidat
Rank: Apprentice
Rating: 0%, 0 votes
Kodak 1-800-431-7278 Option 3
Part Number 3F2247 - ~$15, incl. shipping...
Was this helpful?
Yes
No
Solution #6
posted on Jan 16, 2009
Not Rated)
rt262
Rank: Apprentice
Rating: 0%, 0 votes
My door broke also,Igot a new one here http://www.sdcamerasolution.com/index.php?p=product&id=194&parent=18 it was easy to install.
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
What are the best compact cameras in the $200 range?
Answer
Hello, I have a Samsung digital 30Xoptical zoom digital 1200X camera and i don't have the... (More)
Answer
battery is recharged and full but camera says to replace battery pack
Answer
What to know what cost fix a ditigal camera to put a battery door on only call me at 618 7998787
Answer
I am trying to delete still photos from FC F3356771. Help.
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 28, 2008
my door is broken too, any idea where to get a replacement?
Comment by Guest, posted on Aug 07, 2008
The Battery Door will not stay closed because the small plastic rod that holds the door closed is broken. Good old fashioned tape to hold the door closed is the only way I can use the camera...most aggravating. Where can I get a replacement camera door for my Olympus C-740 Ultra Zoom camera?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
