Possible blocking of the drain outlet, possible blocking of the drain pump/valve.
you must also check if there is power to the drain pump/valve when the program come to an end to drain . If there is no voltage the program controller can be faulty.
If present the drain valve/pump must be checked, cleaned or replaced.
