Question about Jenn-Air JES9750AAS Electric Kitchen Range
Oscillating burner elements
Is it normal for the burners to oscillate on and off? We purchased a house that has the JES9750AAS glass top stove and my wife keeps telling me I need to get the unit fixed because the burners get bright orange and then seemingly turn off. It will oscillate back and forth every 15 to 20 seconds. My wife claims it takes forever to cook anything....help
    President:
  • 1,462 Answers
It is normal for elements on a hob to oscillate on and off. the period on/off is determined by what you have set regulator to
Posted on Jul 12, 2008
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
Feb 12, 2011 | Microwave Ovens
Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
May 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
JBP75GS1WH 3 TOP BURNERS NOT WORKING
it could be bad connections at elements or bad elements a volt meter works good for this problem
Dec 10, 2007 | GE JBP60 Electric Kitchen Range
Jenn-Air JES9750AAS Electric Kitchen Range Logo
95 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
