Question about Vehicle Parts & Accessories
Alarm How do i program my alarm?
  • nbuhac May 11, 2010
    what type of alarm?
  • 347 Answers
What model radar detector do you have?
Posted on Jul 26, 2008
Code alarm protx6 fob programing
I would either go to the website for the manufacturer of the keyfob and search the troubleshooting section or get the company phone number and call them and get instructions for the programming codes. good luck.
Apr 16, 2014 | Audiovox Prestige Code Alarm Remote Alarm...
Can a new remote be programmed if alarm is set?
Hi Kim, When you ordered the new key the dealer should have asked for the chassis number? That gives them the codes to pre program. so that it should activate and deactivate the alarm, if that is the problem! ? Regards John
Jul 02, 2012 | 2000 Pontiac Grand Prix
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Need to know how to program new ignition switch & cylinder
At you year make and model the factory alarm was just the pellet that disabled starter,the alarm was part of the ignition switch if anything you will need to replace the aftermarket alarm. A repair will cost you more than to replace the unit,You will have to cancel the aftermarket alarm under the dash and restore the ignition wire that is spliced for the alarm relay.
Mar 25, 2012 | Cars & Trucks
Hello¡¡¡¡¡ I can't program remote control of explorer 2005, the original alarm is code alarm. What can I do? Thanks
Try looking for a model number on the control unit. Use this number to download the owners manual for the Code Alarm.
Mar 05, 2010 | Code-Alarm Code Alarm Transponder
Will the alarm go off or not?
Hi, alarms can be programmed to chime/not chime etc. Simple way is actually test it just to be sure. Set the alarm and try the door. If it doesnt work, then the door sensor could be faulty OR that chanel could have been programmed to be bypassed. Will require the user man for programming. Best of luck
Jul 22, 2009 | Kitchen Appliances - Others
Alarm problem on my 2001 elantra
This alarm system can only be 'disarmed' using the keyless remote programmed for this specific vehicle. Press the "Unlock" button on the keyless remote -- this resets/disarms the alarm system. If you do not have keyless remote for this vehicle, get one and have it programmed at a Hyundai Service Center. Problem solved.
May 11, 2009 | 2001 Hyundai Elantra
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Optima house alarm
after a power cut alarm goes back to factory setting 0123. you need to use this code to re program alarm
Jul 31, 2008 | Computers & Internet
Vehicle Parts & Accessories Logo
75 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
