Question about Refrigerators
Hello!We have a 1998 Prowler Camper and we have a problem and I would like your advice please.The frige and the lights don't work what could cause this?? Everything else works!!! We have changed all the fuses and it doesn't help either!!! We check the breakers inside & out and they are ok! Please E-mail back at boogieismael@yahoo.com with your suggestions...Thank you Michelle Help as soon as posssible please and thank you...
    Genius:
  • 2,028 Answers
Check the inlnie fuse in the frige.
Posted on Jul 11, 2008
  • Ryan Rogers
    Ryan Rogers Jul 11, 2008
    That's supposed to be inline fuse.
I need a manual for a 1995 prowler 5th wheel camper
Contact your local retailer or the manufacturer directly using this link:
Customer Service Center
Jul 10, 2017 | RVs
Where is the water check valve on 2001 prowler 5th
Usually built into the outside water connection or at the inlet side of the water pump.
May 28, 2016 | RVs
HOW DO I GET AN OWNERS MANUAL FOR A 2005 FLEETWOOD PROWLER REGAL CAMPER TRAILER?
Alicia,
Have you tried to contact the manufacturer directly? You can try this link and see if it helps. http://manualtips.com/archives/p/prowler-regal-camper-owners-manual.pdf
Jan 09, 2015 | RVs
I have 110 at all my outlet's and the a/c work's but I have no 12 volt (lights in camper don't work) where's a good place to start on this
Your lights are 12volt.
Either, the lights work off camper 12V dc battery...
Or they work off 120Vac transformer with 12Vzc output.
If lights work when camper is not plugged into 120Volt, and there is not separate fuse or circuit breaker for the lights, then I guess the light work off the battery.
There is probably a cartridge fuse located under steering column
Many items on dashboard are fuse-protected with plug-in fuse available at auto parts.
Call local auto shop and ask where the fuses are located, or call local RV shop.
Apr 18, 2013 | Electrical Supplies
Just purchased a new 3V CR123 battery for the prowler. The lights are working whenever i click ON or IR, however when looking through the lens nothing is visible. It's just all black. I removed the...
Jello, you meam that IR isn't emitting red light? If the IR isn't working then it has a bad IR luminator, broken wire, bad switch. Now the on/off switch get it power from battery to IR, it just one simple circuit. Also don't look at the IR light if it's on. Also don't point or look at bright lights with this NV devices, it will destroy the image intensifier tube. stewbison
May 30, 2011 | Bushnell Prowler 26-4050 Monocular
Hi, When I push the start button on my prowler 720 control box, it automaticlly goes from green to red. When disconnect the prowler from its control box it stays green. Is there something on the prowler...
The power cord pins are numbered, 1 through 4. So are the transformer plug holes (the female pin holes in the "power pack"). For example, if you don't match number 1 to number 1, the green power light on the transformer will light for about 5 or 10 seconds, but the robot will sit there... well, like a powerless robot. Match the pin hole numbers and you have a working robot!
Apr 22, 2011 | Pentair Prowler 720 Pool Cleaner
I can't see any object in my night vision monoscope. The batteries are new.The indicator IR and ON are illuminated when switch to on.Please advice. Thank you very much. Respectfully yours, Remigio...
Hello, did you turn the Bushnell on. There two switches one for the on/off the other is for the IR and it say on as long as your finger pushs the button. Have you used during the daylight hours, looking a bright lights. If you have, the NV has gone south in one hurry.
If want come on even though the on/off switch working. If the NV devise is work there will be a green LED on the back indicating that the devise is on. stewbison
Feb 02, 2011 | Bushnell 4x50 Prowler Night Vision...
Recently purchased and did not come with owners manual and want to learn the trailers accomidations
You can order a Fleetwood Owner's Manual by sending a check or money order for $8.00 to the address listed below. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood Service & Training Center
PO BOX 1007
Decatur, IN 46733
May 25, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
