Question about Canon PowerShot SD600 Digital Camera
Lens error, restart camera
Please PLEASE can you PLEASE help me- my camera just started doing this and i had just taken a picture w/ it right before- nothing out of the norm.. i really need my camera!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 30, 2012
  • 641 Answers
SOURCE: Lens is stuck out
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 04, 2007
cyrylthewolf
  • 143 Answers
SOURCE: Lens error
It definitely does sound like one of a few things:
  • The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes out.
  • The motor or servo that drives the transmission system is failing.
  • There is a physical deformity of the lens architecture itself that is preventing the lens from coming out.
Any of these symptoms is most likely going to be accompanied by a grinding sound. Especially if the gears are somehow stripped. The "puttering" sound be a description that would fit the sound a motor or servo makes when it's trying to cycle itself over but is failing. (Much like a car that is trying to start up, but just won't turn over?) That would definitely be an indication of a motor going bad in the camera.
Either way, this is something you're definitely going to have to refer to Canon's technical support on. If your camera is still under warranty, you're going to have to get them to replace it or at the very least SERVICE it.
I myself will ALWAYS insist on REPLACEMENT. One might argue that the terms of the limited warranty state that they reserve the right to either replace or service the device...
...but TRUE customer service tells a different story. I have NEVER had anything serviced. I have always had replacements. Either I've INSISTED on it or they've just been smart and not even made it an issue by making it their procedure. I get a brand spankin' new device and THEY get a happy customer.
Always keep in mind how much you spent on their product and ENGRAIN that into their heads.
Here's the deal...
If you ARE out of warranty, get around that by telling them that you DID buy it within the last 9 months and that you do NOT have proof of purcahse. If they insist on asking for it, then humor them and "try" to look for it and once again inform them that you do NOT have it.
They can't really dispute the warranty at that point if they can't prove that you DIDN'T buy it within the last 9 months.
I hate to work the system like that... But I paid $400 for mine. I'll be damned if I'm going to be out the money for it! Am I right?
Anyway... That is the best advice I can give you, unfortunately.
Call them as soon as you can! Get it replaced!
If you think that you can keep yourself together and composed well enough to play the system... Contact Canon's tech support and see what you can accomplish.
Remember... It's not as if you're going to get in any trouble. The worst they can do is refuse you. You have NOTHING to lose but the money you spent on the camera!
Here is their support info.
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Good luck with this. Let us know what comes of it. :)
Cyryl
Posted on Nov 17, 2007
  • 64 Answers
SOURCE: Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Posted on Sep 12, 2009
  • 11967 Answers
SOURCE: Lens Error, restart camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 02, 2010
Jimsta01
  • 405 Answers
SOURCE: when i turn on, it says lens error, restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 05, 2010
How do I fix my camera or can it be fixed at all?
cost will exceed what a new camera would cost probably .
Jun 21, 2015 | Canon PowerShot SD1100 IS Digital Camera
Message on camera screen reads: lens error, restart camera. I have charged the battery, removed and reinserted and same message returns. I am unable to view pictures taken or to take any pictures. ...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 11, 2011 | Canon PowerShot SD1000 Digital Camera
Canon sx200 is, lens error restart camera, after taking some pics I wanted to delete them, so after deleting one picture I've got black screen and the message "lens error restart camera" and the camera...
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Canon Cameras
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
I caoldnot find restart botom on camera
when i am goning to start the camera, it is show this alarm "lens error, restart camera", but i couldnot find restart bottom?
please help meeeeee
Jan 01, 2009 | Canon PowerShot SX100 IS Digital Camera
"lens error please restart camera"
Hello!!
Remove the batteries and keep pressed the power button for few seconds it will reset ur system!!
Oct 21, 2008 | Canon PowerShot A470 Digital Camera
Lens
The Lens drive is shot Canon customer support will advise I my opinion if the camera is more than a year or so old the repair cost will be high.
Aug 01, 2007 | Canon PowerShot S3 IS Digital Camera
Need help with my camera
LENS ERROR. Contact repairs and tell them you have a lens error. Lie and tell them u already talked to tech support otherwise they will try and transfer you to them and they will just make you call repairs again. Repairs is 800-706-2534 and then keep choosing option 1.
Dec 29, 2006 | Casio Exilim Card EX-S600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
