Question about Epson RX595 Photo All-In-One Printer
RX500 and vista
I have an RX 500 all in one. I put in the installation disk and it says it will not recognize the operating system. Now what
  • aacme Jul 12, 2008
    Thank you....but we need the software that goes with the printer so we can install the smart panel.
    any ideas.
    Genius:
  • 1,447 Answers
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
Posted on Jul 11, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 12, 2008
    Im sorry but the smart panel is not compatible with vista, i mean the one that came with the install disk, you can check smart panels manufacturer for updated version that will work with vista though
Need to remove queue error from Dell PC & Epson RX 500 printer
I would uninstall all versions of the printer and reboot the PC. Check that no remnants of the printer software are left on the PC and then re-install the printer. Use the CD that came with the printer when installing.
Jan 19, 2014 | Epson Stylus RX500 All-In-One InkJet...
Epson stylus photo rx500
You need to download the drivers again
Apr 14, 2008 | Epson Stylus Photo RX500 Printer
Several attempts to install windows 2003 on dell optiplex 780 have been unsuccessful. all i get each time is a blue screen.
Windows 2003? There is no operating system called "Windows 2003". There is Windows 95, Windows 98, Windows ME, Windows 2000, Windows Milenium, Win Xp, Win Vista, Windows 7 ect. But no Windows 2003.
If you are trying to install an operating system on a Dell computer, put the disk in the cd or dvd drive on the pc and close it. Then turn the computer off and reboot it with the disk in the drive. After the computer reboots, it should recognize the disk in the drive and bring up the installation process automatically. Sometimes you have to reboot the computer 3 - 4 times in a row with the disk in the drive in order to get it to recognize the software and boot from that drive.
If the Dell does not have an operating system on it and you are trying to install windows from a disk, it may not auto recognize the program in the drive and the above instructions will not work. If this is the case, then you need to put the disk in the drive of the pc and restart/reboot it - and watch the computer screen as the pc restarts - look at the lower left side of the screen during the boot up process to see what keys you need to press to enter startup mode, or get into the bios system of the computer. when you boot up a pc, it will display the keys you need to press on the screen for a brief few seconds before the "windows" screen appears and it completes the start up. If the pc is running windows xp, the command keys to press during start up might be F2 - F8 or "press the delete key". The commands can differ depending on which version of windows you are using - and they can also vary by brand of pc too.
You need to put the pc into "safe mode" or get into the Bios system or restore area to install windows if the computer does not already have an operating system installed on it.
To put the pc into safe mode or get into the Bios System, you need to press the right keys during the start up - and do this before a picture appears on the screen or the windows display comes up.
Put the disk in the drive and reboot the pc. As soon as it starts to reboot, keep pressing the F8 key. If the pc does not go into Bios or say "loading safe mode" then immediately restart the pc and try again. Sometimes it takes 3 or 4 attempts to make this happen. If the F8 command does not work after 4 tries, then try the F2 key. After four tries if that does not work - try pressing the delete key.
If you can get the pc into the bios system - use the arrow keys on the keyboard to scroll through the options and find the prompt that says "boot order". change the boot order to boot from the Cd or Dvd drive instead of the hard drive. Save after changing this setting and reboot the pc with the disk in the drive and it should boot from that disk to install the operating system. Try rebooting 2 or 3 times after changing the boot order to the disk drive to get it to boot from the cd. Then just follow the prompts to install the operating system and your done!
Jul 07, 2011 | Computers & Internet
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
Will this drive work on a vista 64 bit system?
Try putting the same disks into some other CD/DVD reader, to confirm that the disks are "good".
It definitely should work in XP, XP/64, Vista, Vista/64,
but you could have the misfortune to have purchased a "lemon", i.e., a factory-defective unit.
Got another computer to which you can temporarily connect the new drive, to confirm that the drive will work "somewhere" ?
If all else fails, take it back to the retailer, and get them to demonstrate that it works in one of their computers, using your disks. If it does not, then they should replace it with one that CAN read your disks.
Nov 27, 2009 | Toshiba PA3761U-1DV2 DVD-RAM Burner
I have a new pc windows vista. my sofeware for my epson rx500 wouldn't load. where or can i download a upgrade for vista and how
The following URL explains what you need to do:
http://www.epson.com/cgi-bin/Store/support/supAdvice.jsp?type=highlights&noteoid=85987
The page advises you to plug in your USB connection from your printer. You will get the Found New Hardware window. The choose the Locate and install driver software (recommended) choice. A connection to Microsoft will be made and the necessary drivers will be downloaded.
Aug 24, 2009 | Epson Stylus RX500 All-In-One InkJet...
Installing windows xp on toshiba protege 500
When you power up press F2 or "del" to enter in bios .
then set first boot option to as your dvd drive so then put winxp disk then it boot with it.
Jun 21, 2009 | Toshiba Portege M400-S5032X Tablet PC
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Epson RX595 Photo All-In-One Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
