Question about Kirby Ultimate G Bagged Upright Vacuum
Assembly just bought used vacuum, with no manual. Can't figure out how to assemble handle. help thanks mike
    President:
  • 1,673 Answers
The handle just snaps into place on the top. there is a handle pivot, it goes in that. The bag, put over the exhaust hole on the right side, make sure it locks into place, the bag top will snap into the top part of the handle.
Posted on Jul 13, 2008
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 | Vacuums
I just bought a Hoover Windtunnel upright with bag, #U6485100. When installing the handle there was tape over the top with instructions do no remove until assembled. After assembling (screwing in the...
Be sure the on/off button and the power drive button are both in the OFF position before installing the handle. The actual switch inside must also be in the OFF position.
Feb 27, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum before and my wife had the same issue. The neutral/drive pedal just fell out so I figured I would give it a shot to see if I could fix it and quickly figured out the 3 screws in the bottom plate for the drive unit wasn't the answer.
I was able to figure things out out after I found a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive G6 558499A
Here's how to get to a point that you can get these two parts in/out of the machine.
- Remove bag and fill tube from handle and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws at the handle fork plate (these have loctite on them so needed a socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate vie the screw with the power cord anchor and screw by the Pedal Cam For Neutral Drive. Note release plastic tab in slot in the center and lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the power drive assembly so I could figure out how to put the dive assembly back together. The pressed on arm that drives the cam assembly had pulled of the pedal shaft so this also made it easier to fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside.
I assume at this point you could loosen the screw (don't remove it, it's the only one with a star lock washer on it) on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam out and a new one in if you can get the part and replace it. The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take the power drive assembly out:
- Remove the 4 screws from the Cover Shell assembly - the metal top part. You do not need to remove the hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket assembly that has the handle attachment and forward/reverse switch. It attached by two wires. I only disconnect one and swung it to the side.
- Snap off the the on/off switch and disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now drop out the bottom.
I just put the spring washer and arm back on the shaft and reassembled. I'll see how long that lasts before before buying the new part.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Height adjustment won't work
The height adjustment for the vacuum will only work when the handle is in the released position. The knob will turn easily when the handle is locked upright, and when released you should feel a fair amount of resistance.
Aug 30, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Assembling a steam vac handle part
when the machine comes new the way it is installed is to put the upper handle on the lower handle, install the bolts & nuts (tighten) and then to pull the trigger and press the surge button (if this model has one). you will feel them snap together. the clips on the rods should be at 90 degree's from each other. one will be a u type channel and the other a v type and will connect.
Jan 07, 2009 | Hoover F5810 SteamVac Upright Vacuum
Vacuum Power Switch on Handle Doesn't Work
The switch is very cheap. I have the same vacuum. The solution is to stick a thin peice of cardboard under the slide track for the rod in the handle assembly. You will see the rod when you disassemble the handle for the sweeper. Move the on/off switch on the handle assembly a few times and look at the bottom of the of the assembly to see a thin black rod with cut grooves. This rod activates the on/off switch.
There is a little track that this thin rod of plastic travels along. However over time the the plastic rod begins to recess further into this track. The rod still slides but is now to far away to activate the on/off switch. This isn't very technical but just slide a thin peice of hard paper or cardboard between the rod and the slide track.
Make sure the red on/off switch on the sweeper is set to off. Put the handle back with the switch in the off position. Test the sweeper using the handle a few times before reassembling the screws. This fix may not be permanent according to how you have the paper/cardboard set between the slide track and the rod but it works very nicely.
Hope this helps! : )
Apr 08, 2008 | Vacuums
Putting new vacuum together position of the handle
The handle should be attached so that the open portion of the handle is facing towards the brushs( away from user)
Sep 03, 2007 | Dyson DC14 Full Access Bagless Upright...
Belt replacement
The belt handle should be turned so the red arrow is lined up. Then make sure the belt is hooked on the inner assembly handle. Reconnect the vaccum assembly to vaccum and turn handle to allow green arrow to align and the belt is hooked on motor rod anmd your ready to vacuum.
Jun 16, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
77 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
