Question about Kenmore 46462 Front Load Washer
Inconsistent spin? Model 46462, 2 years old. It was inconsitently spinning, cleaned pump. Called sears, sent tech who diagnosed as a motor failure, we refused sears service as we could get a motor in a shorter time period. Replaced motor, still not working. We think it is a f1 code, although we don't have a window--the manual said something about the blinking and add garmet light coming on means f1. What should our next steps be? My husband is suggesting replacing the ccu or the mcu or both. Any help would be very much appreicated.
  • 413 Answers
This type of issue may also be related the the water level switch. If the water level switch fails it can cause the washer to only spin slowly because the CCU thinks there is too much water in the machine.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 12, 2008
WHIRLPOOL WASHING MACHINE WILL NOT SPIN SEE ADDITIONAL DETAILS
Sounds like your gear casing is broken inside, motor is spinning but transmission shaft where agitator sits on, is not spinning.
Apr 15, 2015 | Whirlpool Washing Machines
417 front load washer -
have you cleaned the filter
if its two or three years old also check the motor brushes
Dec 31, 2013 | Sears Washing Machines
Have kenmore washer 8 years old will wash clothes and let water out but clothes not spinning. doesn't have belt on it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Since it goes through it's cycle and pumps the water out, we can assume that the motor and timer are working. This points to two places.
There is a motor coupler (see the Sears sub category for motors and pumps in the Sears list) that provides power to the transmission from the motor. It's a fail safe device to protect both in case one of them jams.
Second, inside the transmission are a number of cams called the Neutral drain assembly that allow the machine to drain for a time and then begin the spin cycle.
On our machine, one of the cams that is supposed to have a spring didn't and the machine wouldn't spin unless frorced.
Here is a Whirlpool document with all of the components of their commercial grade washer, the consumer model is basically the same. Check the section on the Gear Case and look at item #26.
If you are relatively mechanically inclined, it isn't to hard to pull the transmission and get to the gears and cams. It's messy but can be done saving quite a bit of cash. (It cost us $15 for the assembly vs. $170 for a transmission.
Following is an excellent description from GURU JSROCK516 of how to remove the cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 12, 2009 | Kenmore Washing Machines
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Kenmore HE2 flashing lights
had an old pressure switch that I thought was the problem I had from something else a year ago
That was the washer not starting, all kinds of lights
I took the back and top off and reconnected all the plugs.
Had a loose connection somewhere, it worked after that.
I blew into it and put it back on.
The rattleing quit in the pump after it pumped out, while the drum was spinning slow.
Now working ok
Nov 24, 2008 | Kenmore 46462 Front Load Washer
Frontloader pumps water out but won't spin
You need to replace your drive coupler. You can get the drive coupler at sears online or your local parts store. After you get the part go to sears online, Put in your model number and it will bring up a diagram to show you exactly where it is. The drive coupler goes between the motor and the transmission, It makes it spin and agitate.
Nov 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 46462 powers off during spin cycle - no lights
i cleaned out the pump under the front bottom panel
Feb 03, 2008 | Kenmore 46462 Front Load Washer
Maytag fav6800aww wont spin
I have a 3 year old neptune top load and have experienced the same problems you all have had here. Problem: Washer was leaking 1/2 gallon of water every load and sounded like a freight train on spin cycle. I usually do my own repairs but didn't have time so I called A&E by the recommendation of Maytag. Diagnosis! The tech said the tob o-ring seal was bad as well as the transmission. I had no reason to dought this professional right. I did after he told me the price... $450 to fix it!!!! I reluctantly gave him his $65 service call fee and said goodbye..
I called maytag and they said the transmission should have been covered by warranty (10 years). The tech was either an idiot or just plain trying to rip me off. I called Maytag back and they sent me the supposed bad tranmission and seals. I replaced them in 1/2 an hour. Guess what.... This did not fix the leaking or the loud spin cycle noise. What is the problem with this neptune model? The problem for every owner including myself has at minimum been the main seal inside the outer tub. This leaking for months took out the bearings causing the noisy spin cycle. I replaced both 6207-2rs bearings compliments of ebay for $6ea. After reassembly it was like new for the first load. On the second load it would stop on the spin cycle.... It would cycle between the agitators and trying to spin but never engaging into spin. After 5-6 minutes it gave me the code that stated an unbalanced load. What the problem was is the leaking had made its way into the clutch as well. I pulled the clutch/pulley back of and cleaned and lubed it. Problem solved! She now goes into spin and has no problems whatsoever. I'll never call A&E again...Mechanically this washer is a piece of cake to work on. Electronically it could be a bear... The bearing replacement took approx. 2 hours total from start to finish. Next time I'm buying Kenmore and the extended warranty. I'm tired of screwing with this junk... Good luck guys.... Jos Roach... CA.
Dec 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 46462 Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Robert Rankin
