Question about Neff Refrigerators
How do I replace the door seal on a Neff under the counter refrigerstor?
  • 828 Answers
Some door seal gaskets just wedge into place and are easily replaced. Replacing the gasket is simply the reverse of removing the old one. You peal out the old gasket and fit in the new and press it into the slot.
Posted on Jul 11, 2008
How to pull out dishwasher
Are you asking how to remove an under-counter dishwasher to fix or replace? The best bet would check your manual. If not available, first thing you must do is shut off power to the dishwasher. Usually there is a breaker labeled dishwasher in your breaker/fuse panel. Next, turn off the water to the dishwasher. There should be a valve under the kitchen sink with a hose that leads to the dishwasher. Once that is shut off, you need to remove the lower panel (closest to the floorl, underneath the door) from the dishwasher. You will now be able to access the water and electrical connections. Once you remove them, you're almost ready to pull the dishwasher out. Now you must remove the 2 screws that hold the dishwasher to the underside of the counter. Look up just above the door and you should see two brackets sticking out under the counter. Remove the screws and you should be able to gently pull the dishwasher out from under the counter.
Mar 03, 2014 | Neff Dishwashers
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
How do i fit new door seals for an neff u1421 double oven i have the seals
If the seals have what appears to be hooks at the corners, then unhook the old seals and re hook the new seals into the holes in the front of oven .
If no hooks, then the front of the oven needs to be unfastened.to replace the seals.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Neff U1421 Double circotherm Electric Oven
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
Frost free refrigerstor
use a little vasaline on door gasket and it will be better
Sep 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
113 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
