Question about JVC Audio Players & Recorders
Jvc kaboom box, does not work on batteries, ac power only.
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
I just bought jvc kaboom. I love it, only i have no way of hooking up my satellite radio to it. can i hook it up at all using the usb port?
Apparently the kaboom accepts usb.
http://www.jvckaboom.us/node-493964-B0032WL2FU-JVC_Kaboom_System_for_Ipod.html
"Features: This powered woofer CD system features twin super woofers with powerful bass sound, connection for iPod, and USB host."
What do we know about your Satellite Radio?
Jan 22, 2011 | JVC Audio Players & Recorders
Hi...every time I turn off my RV-B90 I have to unplug it and plug it back in before I can turn it back on. Any fix for this?
This was happening on mine and here is how i fixed it.
I would hear clicking from the cassette area when i first turned it on, and the door would be jammed and i had to brute force it open. The kaboom would not shut down by using the power button or remote. Nothing!
I found the tape mechanism was getting jammed out of place because of all the gunk so I cleaned the inside with isopropyl alcohol and a q-tip then moved the mechanisms back and forth with my finger on the bottom where the tape goes over the sensor.
I powered it up with no clicking and was able to shut it off with the power button and remote again. My power issues had to do with the tape player whodathunkit.
Apr 19, 2010 | JVC RV-B90 Boombox
JVC Boomblaster RVB90 has problems to start after shut down.
If you have a cassette tape in the Kaboom take it out close the casstte door and lock it. See if the problem continues. The cassette circuitry has been known to cause alot of prolems like yours. I think it has to do with sensors.
Feb 26, 2010 | JVC RV-B90 Boombox
NOT READING DISK
These units are notorious for this.. mine quit too for no reason at all,, press power button and it shuts itself off. there are no assemblies available from JVC , only parts..
May 07, 2009 | JVC KABOOM RV-NB10 Boombox
Jvc mc200 powers up,beeps and shuts down within 2 seconds
have a jvcgr-smx750 . It was working fine but recently I powered it up with battery, without battery and just ac power cable. Both times it does power up and shows the screen for about 2 seconds, beeps, and then shuts off. Please help
Apr 12, 2009 | JVC Video Cameras
Dead KABOOM JVC Boom Box RV-NB10?
Sounds like the Fuse on the power supply board. Gonna do an R&R
of my fuse in a few days.I purchased the .PDF service manual for about ten bucks.
Mar 14, 2009 | JVC KABOOM RV-NB10 Boombox
Display light out
Hello, I've had JVC RV-B90 Boombox for few yearst too, but display lighting is ok, There is just small bulb, so take it apart and just change bulg for new one. Good luck !
Jan 17, 2007 | JVC RV-B99GY Cassette Boombox
54 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
