Question about 2wire 2700HG-B Router (2700HGB)
2wire router hi, just wandering if you ever found out what the prob was as im having exactly the same prob please help if you can thanx gem missf0rtune@hotmail.co.uk
  • 3 Answers
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
Posted on Jul 29, 2008
Yes im trying to connect to the internet on nintendo ds xl it as an error code 051310-1what can i do
Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings.
Let us help! Select the brand of your router below and we'll show you how to access your router's settings. Linksys Netgear DLink Belkin Apple 2Wire All other brands
    Once you have entered the correct WEP or WPA key into your system, try the connection test again. If the problem persists, keep reading this page.
Additional information:
  • Using an Actiontec or 2Wire router? The default security key is often found on a sticker located on the router.
  • Security keys are case-sensitive.
  • WEP keys contain numbers 0 through 9, and only letters A through F.
Feb 20, 2011 | Computers & Internet
I need drivers for Vista
hi
plz go thru the link below
http://www.nodevice.com/driver/company/2wire.html
and check it whether it is a trusted site and then u can scan it for your virus. u can even consult with ur comp vendor for its security
thanx and regards
sukhiii
Jul 25, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | 2wire HomePortal 100W (1000-400026-000)...
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting to Ichat
Please click on this link you will find exactly what you need to do exactly(with pictures) ,,
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/iChat.htm
Jun 05, 2008 | 2wire 2700HG-B Router (2700HGB)
Noisy phone line with 2wire rpoter
if the line is clear, just use a line filter only where you have a phone fitted and nowhere else, that way you can try the different filters if you are using more than you need as it sounds as if one may be faulty. Also check any extension leads you may have or remove and check you phone line again for noise. If there is noise it would normally stop you from connecting to the internet also.
Jul 01, 2007 | 2wire (1000-400108-001) Router
2wire 2700HG-B Router (2700HGB) Logo
48 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
